Kagamoosha
1 W
I just recently bought a triangle shaped battery from Calibike.com that came with a BMS installed. It is a 48 volt 13 series 9 parallel made of 18650 cells. My other battery is a 48 volt 15 series 10 parallel also 18650 cells. Is there a way of connecting these two batteries using the 14 pin connection so I can manage and charge both batteries in parallel. Even if I had to remove 2 of the cells, so both batteries have 13 cells in series, but my ideal situation would be to have both batteries fitting inside the frame bag I have. I know that if I just connect the two batteries in parallel they have to have the same voltage or they will not work correctly, so any suggestions would be greatly appreciated.
http://calibike.com/?product=48v20t-electric-bicycle-ebike-48v-20ah-lithium-triangle-pack-battery-and-charger-1-yr-warranty
