Hi ESFMs,
I just range tested a second pack I'm adding to my frame. It's a 48v 14Ah. In the weeks leading to this pack's arrival, I calculated that it should get me at least 20 kms of range. And tonight, I managed to squeeze about 24 kms until the LVC made my throttle redundant. So, I'm actually quite satisfied with that result.
However, I also set up my wattmeter to ensure that I had most of the rated capacity, as I've done on previous packs. What I found weird was that it was under rating my output of Ah. I stopped at the 5km Mark to check the reading and it read 1.726Ah. But I know from testing previous packs that I should have been in the 3Ah ballpark.
By the end of my range test, my wattmeter stated only an 8.6Ah capacity. I expected a slightly lower read out than the rated 14Ah but that's a massive 5.5Ah short.
This seems especially odd as the cells are the same that I have in my bigger 35Ah pack. Sanyo GA 3500mAh.
How accurate are wattmeters for measuring Ah? And is it normal for them to be off by such a margin? I've only used this wattmeter a couple of times and had it since around May or June. Maybe a little later. Come to think of it, this might have been my first proper use of it.
Clinton
Clinton
