Peterfr12
Dear ebikers,
I finally finished my new setup a fully suspended Recumbent powered by a MXUS 3kW hub motor, a 12F nuculear controller and a 20s14p homemade battery (84V 49Ah). Both front and back wheel are motorbike wheel.
I tested my new setup today and yesterday on a flat road for 24 km under the rain, asphalt and then a sandy road. It is great compared to my previous setup with a Mac motor. The MXUS motor did not overheat at all and the temperature was close to 33 C (vs 90 C for a mac motor). This was my main issue with the Mac motor, unable to sustain long trip without reaching 100C quickly. Regen is great since my rear brake does not work – it will require bleeding – and the brake pads are touching the rotor.
Speed on flat : 66 km/h (41 mph) with a 73V battery and 1800-2100 W. 64 km/h without any issue on the sandy road along the canal; it was empty because of the rain so safe. Motorbike tires are a relief. I will add a fairing later to protect me from the rain.
Now the issue I have : when I go over bumps the top of the frame - where will be the topcase -is touching the mudguard of my bike. I am only 145 pounds. I have a rear suspension a DNM DV22AR (I am aware it is a cheap one). I can change the distance between the rear fork and the frame by putting the top part of the suspension to another hole, but it will lift the seat to a position more perpendicular which I want to avoid. Lying in my seat like in a bed is better
. I have no technical knowledge on suspension but for me the spring is too soft so how can I harden it? Or how can I change the limit of the damping. The red button is for the rebound force adjustment so I shall not touch it. There is a massive nut on top of the spring, but I cannot unscrew it. I could adjust it in the past but now it is stuck. Or can you let me know what should I purchase as a new rear shock?
Thanks for your help.
Peterfr
Peterfr
