So.. yet another " wtf " adventure in ebike repair !
16" iZip ezgo folding bike, 24v SLA, LBS got in touch needing help...
Story goes, customer took it to them with broken spokes, needing repair.. they removed the wheel and swapped the spokes, then gave it back to the customer ( was dropped off without battery pack, so LBS could not test it ) .. then it came back and customer says it won't run. ... email from customer says something about he looked at it and found the colors between the motor and controller did not match, he tried swapping them but no joy ..
When the controller is given power the motor spins rough, when the power is removed the wheel turns free..
So, if there was a kinked wire causing a short, the motor would cog with or without power, so that's not the issue.
I opened up the controller box, it's Ananda brand, potted..
I put a Lyen tester on the phase wires, all 3 phase light up in forward and reverse ( geared brushless motor, no freewheel ) have not yet tested hall sensors..
But my best bet is the controller is toast .. but usually when the controller is shorted the motors cog with or without battery power applied..
thoughts ?
thoughts ?
