professorcake
- Joined
- Mar 17, 2015
- Messages
- 24
Think it might be a little bent...
dequinox said:Nice build, and I wasn't aware that SBP was selling electric kits now... The last time I dealt with them was 2009, and they were a pleasure to work with as I recall.
The complete kit for $329?? That's pretty cheap, and I wish I had known then what I was getting into with my build... I used SBP components and some custom stuff, and ended up spending well over 700 at the time... as well as countless hours of cussing and re-adjusting the thing.
I'm glad to hear your build will do 30-ish. I've found that's a comfortable top speed for me on the road, and it's not always easy to achieve with a hub kit unless you want to spend a little extra. I like the ability to shift too, as I find it gives me a better range of control. Hub motor advocates might say that hub motors can be reconfigured for any speed range, you just have to think ahead and buy the right winding. I find this to be a bit like the manual vs automatic argument. Yes I could get an automatic, and driving would be easier... but there is something about a manual and clutch that I just like.
As to your skipping issue, if you're still having it, I'd check the vertical chain alignment. You mentioned you were getting skips on the smallest sprocket? I found over NUMEROUS teardown/readjustments of my build that if your crank-to-cassette chain ring alignment is off, you'll have this issue. You have to make sure that crank sprocket is dead-center on the cassette when viewed from above. You can't adjust the cassette very easily, but you can shim the SBP chain ring fairly easily I've found. The chain ring can also be adjusted by using different length bottom bracket spindles. You just kinda have to play with it until that alignment is optimized... see the graphic below. I didn't ever really get skips again after I had this adjusted properly.
professorcake said:Think it might be a little bent...
dequinox said:professorcake said:Think it might be a little bent...
:lol: Sorry about your wheel, I've been there... well sort of... broken spokes and all. Go double-wall, as in buy a decent wheel. There are $40-50 wheels, then there are $150 wheels. After busting a bunch of spokes on the former, I chose to buy the latter. I suspect you are doing this on trails though... mine's just a commuter.
Voltron said:Just an fyi on the chain skip, its not cheap but the new Shimano derailleurs have a switch that puts super spring tension keeping the cage pulled back...then you can switch it off for taking the wheel out. They developed it for the Bosch drives to help with the low wrap they have on the driver sprockets.
professorcake said:haha yea I should probably invest in a decent wheel. My local bike shop kinda gave me the bike shop snob routine today. Told them about my bike and how I ride it and they quoted $90 for a similar wheel, $125+ for something better. Then immediately suggested I "sell my bike for $300 and buy this $1100 trek". Then continued to lecture me on how ebikes are illegal on official trails because they put too much wear on the tracks. Thanks but not thanks I have no intention of selling my bike, way too much fun... especially at that price. I mean I know the bike itself is nothing special bike but really?
professorcake said:
