BatteryMan
- Joined
- Oct 10, 2016
- Messages
- 23
I have several questions regarding my ebike build.
I bought a 500w Bafang motor and I'm mounting it on the front wheel. I'm not using PAS, only the throttle. I plan on using the throttle as one would use Nitrous on a car. Meaning, if I'm going up a hill, or if the wind is blowing right in my face and I'm going 1mph on a flat surface.
In this case, do I even need the ebrake that came with the kit?
Also, how exactly does the ebrake work? What I mean is, if I do want to install it (as a safety feature in case the motor short circuits or something and gives me 100% power) can I just mount it anywhere without hooking up the brake line? If I just pull on the ebrake lever without actually putting in the brake cable in there does it still work?
I am including a photo of my bike, you can see that I can't actually replace the stock brake lever with the motor kit ebrake lever.
BTW, the Bafang kit came with the thumb controller that doesn't have quick disconnect, meaning you have to unhook everything on the bars to mount it. I ended up having to spend $20 on a quick release one which was a bit annoying. They really should include a quick release mount.
