RC Motors - How to Choose Kv
Here's the thing, if I choose a kv that is super low, I need a high voltage to get max power out. But what if we plan on keeping the voltage down? Then a kv should be chosen that gets full RPM out of the motor by the time full battery voltage is applied.
Right?
Does it make sense to run a bike on high voltage? If we can choose whatever voltage we want, and whatever kv we want, how high is high enough? And which should be high, voltage or Kv?
Here's what I found out:
The limiting factor in all of this is the controller. You can not just specify a voltage and get everything else to fit. Controllers do not come in every voltage you might want.
Currently, sensored controllers can be found up to 100v, but sensorless controllers (RC type) go up to 50v max.
I want to use a RC type controller, specifically the Castle HV 160 which has a max operating voltage of 50v.
Here are some other RC controllers, take notice of their voltage limits
hextronik 120A 25V
total power 3000 watts
$60
Turnigy 2000 200A 48V
total power 9600 watts
$190
Turnigy Sentilon 100A 48V
total power 4800 watts
$116
Hacker X-70 70A 24V
total power 1680 watts
Castle HV85 85A 50V
total power 4250
$210
Castle HV110 110A
50V total power 5500
$270
Castle HV140 140A
50V total power 7000
$360
As you can see, if you want to use a RC controller, max battery voltage must be 50v or below, preferably 48v or less to allow some headroom just in case.
If we assume that we will use a 48v limit, and a 130 kv motor, how fast would that get us going? The reduction ratio determines this, so lets do an example:
Given:
Wheel: 700 C wheel
Motor: Turnigy TR80-100-A
Motor kv: 130
Max voltage: 48v
distance wheel travels in one revolution
= pi x diameter
= 3.14 * 70cm
=2.2 m/wheel revolution
Given:
1st stage reduction: 4 motor to 1 jackshaft
2nd stage reduction: 6 jackshaft to 1 wheel
Total reduction
= 4 * 6
= 24 or 24:1
Given:
motor rpm at 1volt = 130 rpm
Min motor rpm
= motor kv x voltage
=130 x 1volt
=130 rpm
Min wheel rpm after reduction?
= motor rpm / reduction ratio
=130 / 24
=5 rpm
5 rpm is how fast in km/hr?
= rpm x distance wheel travels in one revolution
= 5 rpm* 2.2 m/wheel revolution
= 12 m/min (or 0.7 km/hr)
Max motor rpm at 48v
= 130 kv * 48v
= 6240 rpm
Max wheel rpm after reduction?
=6240/24
=260 rpm
260 rpm is how fast in km/hr?
=260 rpm * 2.2 m/wheel revolution
= 572 m/min (or 34.3 km/hr)
How to choose a Reduction Ratio
Minimum reduction means lowest losses to friction, soI think that the minimum reduction possible is the way to go. Single stage if possible, double if necessary. The highest ratio I've seen so far in one stage is about 10:1 while double stage reduction (using a jackshaft or planetary gears) can get up to 30 or 40:1
We want a Kv that is high enough to hit the mechanical limits of the motor at the max voltage of 48v. Astro motors being custom wound come in a variety of winds, with many different Kv choices. Let's take a look at the chart.
Lowest kv is:
12 turn for 113 rpm/volt
but the highest rated controller is 50 v, so actual top rpm would be
50v x 113 = 5650 rpm
Apparently, these motors are good up to 12,000 rpm, so we are losing some power by limiting the rpm.
how much of an RPM loss is this?
12000-5650 = 6350 rpm
6350/12000 = 53%
Wow, that's huge!
lets try a higher kv winding:
8 turn for 169 rpm/volt
50v x 169 = 8450
Still too low! So what voltage would get us to max rpm?
12000 / 48v = 250 rpm/v
Now, this is the calculation to get max power from a given motor. I you want less power, you have two choices: be gentle on the throttle, choose a lower kv so that the motor runs slower at the max voltage that the controller puts out.
Why would you want to do that? Well, if you run the motor at max rpm, it's going to be louder, and have a higher pitch to the noise. Maybe you don't like that? Or perhaps you want to maximize efficiency. If so, you'll want a Kv and gearing for your motor that puts it in the zone of highest efficiency most of the time. What is that zone for your motor? I have no idea, ask the manufacturer.
I am designing for max power, so someone else with experience in that direction will have to jump in here to discuss the alternatives.
Right?
hextronik 120A 25V
$60
$190
$116
Hacker X-70 70A 24V
Castle HV85 85A 50V
total power 4250
$210
Castle HV110 110A
$270
Castle HV140 140A
$360
Given:
Wheel: 700 C wheel
Motor kv: 130
Max voltage: 48v
= pi x diameter
= 3.14 * 70cm
Given:
Total reduction
= 4 * 6
= 24 or 24:1
Given:
Min motor rpm
=130 x 1volt
=130 rpm
=130 / 24
=5 rpm
= 130 kv * 48v
= 6240 rpm
=6240/24
=260 rpm
Lowest kv is:
6350/12000 = 53%
Wow, that's huge!
50v x 169 = 8450
