adsc
⚡ Regular
Started today with my E Motorcycle project. I managed to grab a Kawasaki VN 800 Classic chopper without motor for little money. The previous owner had it already converted to bobber style. I will probably have to undo some of those conversions, as they are a little bit unpractical, for example the fenders which are mounted so close to the tires that a stone stuck in the tire could lead to serious problems. I'm also not a big fan of side-mounted license plates. And the handlebars are a little bit excessive for my taste.
I have a battery made out of 24 Eve LF105 prismatic LFP cells, which gives a 72V battery with a little above 7 kWh. It is managed by a JK BMS B1A24S-15P.
I use a Fardriver ND72680 motor controller. Originally it was supposed to drive a QS 273 8000W hub motor, but I learned that any alteration to the bike frame is gonna cost real big bucks at a test center when you want to get it street legal here in Switzerland, so I also ordered a QS 138, which hasn't arrived yet.
I'm gonna put a 3.3 kW TC Elcon charger on the bike and connect it to a female Type 2 plug, so that I can charge at public AC charging stations.
Today I wired up the basic drivetrain on a Testboard and managed to complete the controller's autolearn mode. The throttle turns the motor and the reverse switch, which is the only other input on the Fardriver I'm going to use, also works. So far so good.
Next up is wiring up the charger.
