Hi all, complete noob. I did try the search function but did not see an answer to this question. I have just received a Kelley controller kls7230. 72v 120amp constant 300amp peak. My question is regarding a cycle analyst or similar lcd system to monitor battery and the like. There doesn’t seem to be a plug for any such device. My old crystalyte system has a 6 pin plug which plugs into the lcd display... is it at all possible to run the same lcd set up or even a cycle analyst? If so how would I connect it to this controller? Obviously monitoring battery use would be ideal... thanks
