drewjet
That came from Kelly.
I never measured it.
when the Puma is running at 72V the rotor is spinning at twice the speed that it was designed to, I think the problem stems from the halls miss firing
Hi Paul. They seem to like the Puma OK on one setting, so I think they should on the other (torque vs speed settings). I really dont think this controller blew because it was on the puma, there was no throttle applied even at the time. That said, the halls situation on the puma is well worth looking into. Richard suggested the same thing (though mainly because of the new x'lytes problems, and these are not only related to high voltages/speeds).knoxie said:Hello Steve
Hmm I was interested to see one of these things naked! are you testing these for Mark? or buying them in for yourself? they look beefy enough to me! I suspect they dont like the Puma though (not many controllers do) I have a theory after lots of messing about with the Pumas that a lot of the controller failures were down to the switching speed, when the Puma is running at 72V the rotor is spinning at twice the speed that it was designed to, I think the problem stems from the halls miss firing, I intend to test this theory out soon with a bit of lab work and an old controller, some of the controllers seem to work ok for a while though and I know that your Puma has been ok at the higher voltage since you modified the fets however I have seen problems with my modified controller at 80V on the Puma. I dont think the Xyltes have this problem as they are not spinning anywhere near as fast as the puma rotor, just a thought, those Kelly controllers look well made, also I think they are too much for the Puma Steve, you are going to start snapping things!! been there done that!!
Good luck with it and keep me posted, I am a little curious why you are running it on your KMX, isnt it fast enough?
Cheers
Knoxie
Are you sure the "4-2" error your getting isn't the "2-4" error you got last time, and you just are counting fromt he wrong place? I got a similar error code from when I fed it too low a voltage on the PWR, but cant be sure if it was 4-2 at this point. I too couldnt find the same code in the manual.. I hope kelly can sort this lot of gliches out!
fechter said:Now, I'm a bit confused. I just looked at the Kelly web site and for the Brushless controller, it states the PWR input should be 18v-90v, 150ma max and 50ma standby. It also indicates a 4-2 error is a hall sensor fault.
As promised, I posted pictures of my current prototype equipped with a 72v100a Kelly:
viewtopic.php?f=6&t=3514
42.7mph so far, 92amp peak draw.
Jozzer said:Ahh Drew, you've got the same problem as I had on the Puma then. Seems the current limiting needs looking at Kelly!
Nice bike Oatnet, good work
shinyballs said:Got my Kelly! nice looking piece...
How did you guys connect the wires to J2? What wire guage did you use?
