Obelous
I have a KLS7230N with a mxus 3k turbo 4T and I am trying to use the risunmotor throttle.
Unfortunately I do not have a multi meter to test the voltages.
So after connecting my throttle to the controller and powering it on I got a pedel-high error, over the course of hours I tried many different TPS low high and deadzone setting none of which seemed to make a difference. At one point I might have had it so there is no error until I twist the throttle.
The pedel section in the monitor page shows 153 with no input and 255 at around 60% throttle and doesnt go any higher.
NOTHING I did changed this. Not the TPS modes, not the deadzones, nothing.
The controller beeped either error 2-4 or 3-3 depending on the settings. I was sometimes fully cutting the power to the controller and then turning it back on as the manual said something about that and the throttle errors.
On TPS mode 3 there is no error but the throttle doesn't respond and also when changing it back to mode 2 the motor quite scarily jumps to life as it bypasses the invalid throttle range check at bootup presumably at 153/255 (60%) throttle.
Any help would be much appreciated.
