Alan B
I always use a resistor in series with the +5 with the resistive type throttles. Otherwise the max voltage out of the throttle is too high which causes various problems with controllers.
is this in reply to my post?Alan B said:I always use a resistor in series with the +5 with the resistive type throttles. Otherwise the max voltage out of the throttle is too high which causes various problems with controllers.
Yes, "overshooting" like that. It is maybe OK for some very heavy vehicle, which needs tens of seconds to accelerate, but for bike it is a big deal.izeman said:are you saying that your throttle is OVERSHOOTING? if so, i have the very same problem. i fully open the throttle, the motor revs up to whatever the fully openend throttle "allows", then when i RELEASE the throttle the motor immediately REVS UP higher than before for maybe half a second, and then goes down to zero as you would expect it.Klasik said:Change throttle delay, also throttle release delay are possible to adjust, but it doesnt work good. I tried to draw what my piece is doing, and it is really really annoying. Anybody has the same problem ? Anybody knows the solution ?
this was the main feature to ditch the controller. no reaching full rpm and this over boost when releasing the throttle made it unsuitable to ride.
even for a car it's not ok. NEVER. it's just counter intuitive. but the question is: WHY is this happening, and could we stop/change it?! is this a bug or a feature.Klasik said:For bike its not ok. Could be ok maybe for car which has 1000kg and 10kw motor. But for bike is really dangerous and very annoying.
markz said:Is there a website that sells Sabvoton's with prices attached.
What is required to program Sabvoton's?
Confusing it with Sevcon.
1). sine wave controller, programmable, with regen function
2). DC Current Limit: 120A
3). Max. Phase Current: 300A
4). Battery Voltage: 24V-96V rated, Max. 120V
5). Thermic Probe: KTY83-122
6). Including one controller + USB convertor cable + matched plug
7). controller size: 283mm*147mm*62mm
8). Net weight: 3.0kg
9). Default not including bluetooth adapter.
10). Default function: Hall, Throttle, Electric Lock, High Brake Level, Temp sensor, 0-5v e-brake, three speed switch, Hall speedometer.
11). Special functions: Reverse, Cruise, Three speed Button, Waterproof, Anti-theft
Notes:
1).We have updated the 0-5v e-brake function.
Old: it should be press the brake switch then can achieve 0-5v e-brake funtion.
Update: you can achieve 0-5v e-brake function without press the brake switch.
2). For no lock type controller, there is warranty service, but we could offer our suggestions for you.
3). CA function not support anymore. You could customize the controller according to our drawing.
4). Pls. make sure all the connection is correct before power on.
Ali Express has decent prices that I have found.Quinc said:Anyone find any holiday deals on Sabvoton controllers?
Thank you sir for the info! Greatly appreciated!shortcircuit911 said:I bought a sabvoton 72150 with tft and the controller didn't monitor motor temp(missing 6th wire on hall sensor plug). The tft screen wasnt great and cut out past 10kw. Also the controller and tft screen blew after just 50 miles. Sabvoton is trash! Buy a mobipus from SamD here on the forum, you wont be disappointed.
Check my thread for the details
https://endless-sphere.com/forums/viewtopic.php?f=3&t=95439
Dui said:As explained here above, I have the 72150 Version, but unlocked to produce 200A instead of 150A.
About reliability, the Sabvoton is a rock, I made countless stupid things with it, ride it everyday at full throttle for 40 to 50 km under all kind of weathers, it endured every possible bad treatment, even a miswiring of positive and negative wirings once (KABOOM), and it is still working after about 3 years of this treatment. So yes, I have total confidence in its reliability. But it is just my personal experience, far from being a scientific assessment.
Roguenite said:I know this is quite old and hope you're still around. When you miswired the positive and negative of the Sabvoton, did you have to replace any components such as MOSFETS? I miswired battery positive to Green phase terminal while negative was wired correctly, on my brand new 96v 120A Sabvoton. Ofcourse then I had to replace all 10 mosfets of the green phase. But as soon as I connect positive and negative (correctly now), FETS of that green phase keeps blowing. I have replaced the fets 3 times now and cant get it to work. Some other component must be causing them to blow as soon as I connect the battery. I didn't get to even do the hall test yet. Can't afford to buy another controller. Paid £350 for this.
