Samd
Just saw this thread mate. Nice.
Who said it was haphazardly hung? I don't remember saying that.tomjasz said:IF you knew diddily about design you'd recognize this isn't your old BMX with a stink box haphazardly hung, and destined to fail.
Kepler said:I think you are missing the point by comparing this drive to a weed whacker motor that you strapped to your BMX bike and to quite frank, a little insulting to refer to the design as 17 year old's technology.
Kepler said:MrDude_1 said:I assume this uses a spring to kick out like your previous one.
When you change out swingarms for longer ones, do you have to change the spring to a stiffer one as well, or can you just preload the spring more?
Or is the spring not important anymore, now that you use cable actuation?
No spring in this design. Just another complication and unnecessary cost. Although the kick spring has its merrett, I have never been happy with how finicky it made the drive setup. Using a cable activation to get the drive to make light contact with the tire is so much more reliable.
I plan to document different methods of adding a simple and cheap cable pull mech. Keep in mind the cable mech is only there to make contact with the tire then the tire climbing action does the rest.
Mündawg said:wow, ya'll need to chill out. I said i was proud of their achievements and i wish them success!
If you're insulted that's all on you buddy. I clearly said that to me friction drives (in general) will always seem like 17 yro's technology (Because i was 17 when i built my own). I made no remarks to the craftsmanship or ingenuity of THIS particular design. I didn't say that THIS design was 17yro technology, ya'll must have missed the point. Also the weedwhacker story was just a fun anecdote, i thought people on ES would be more receptive to that creative spirit.
If you accurately read my post you would see that the issues i was pointing out pertain to my experience with friction drives as a whole, had nothing to do with mechanical shortcomings of the weed whacker i used. I never said that THIS friction drive would have the same problems, but since you're all in a huff i clearly hurt ya'lls feelings with my opinion. It wasn't my intention to put down your efforts and work!
Mündawg
Kepler said:All good questions here.
The weight of the motor holds the drive off the tire when not in use. Yes, it can bounce around a bit when disengaged however keeping the motor to tire clearance at a minimum keep this in check. You do get a slight rattle over rougher surfaces but its not much. A cable tie around the bottom stop pin to act as a plastic stop rather then a metal to metal stop would probably reduce any rattle to next to nothing.
devo1223 said:Is $100 just for the brackets? So we'll need to source are own motor and modify are own KU65 controller?
MrDude_1 said:little off topic.. but the VESC is about the same size as that tab coming out.
if you were to mount one on that bracket.. you would have everything except the throttle and battery all in that one tiny unit.![]()
Kepler said:MrDude_1 said:little off topic.. but the VESC is about the same size as that tab coming out.
The VESC is a controller i am yet to experiment with but i am keen to test. I believe they are sinewave (correct me if i am wrong). Noise is the only real drawback of this drive. A quite RC style friction drive is the holy grail as far as i am concerned.
Just an idea... Add a small toothed gear to the motor axle (such gears are readily available for the intended motor output that otherwise is not being used for this drive). Then extend a small tab on the mounting bracket towards the motor axle with linear gear teeth on that edge of the bracket to engage the motor axle gear, but only when the motor is down, away from the tire. Then, powering up the motor could also cause the axle spin to "kick off" the geared tab throwing the motor up to the tire. The tab would need to be low enough in height such that the axle rolled completely off of it before the motor housing made contact with the tire. Only added part is a gear for the motor, and only a small change to the main bracket shape, adding the toothed tab extension.Kepler said:No spring in this design. Just another complication and unnecessary cost. Although the kick spring has its merrett, I have never been happy with how finicky it made the drive setup. Using a cable activation to get the drive to make light contact with the tire is so much more reliable.
