shorza
Looks like it's going to be great.
Are you worried that the motor will rub once it has warmed and expanded?
I think you will be fine with that belt size. What is it 8mm x 20mm? That will do many many kW's... Especially with that big drive pully. Something tells me, you weren't leaving things to chance when you selected that drive train...![]()
As for the switching aparatus i will keep it untill it becomes a limiting (or failing factor). But it sure is good to know it can handle some abuse on a level that i probebly have a hard time reaching with my relativly low top speed and light weight.Regarding the switching mechanism, I'm pretty sure that the way it works is that in high only half of the current goes through the wires that flex and the contact surfaces, and in low all of the current flows through it. The only example of a failure I could find was back in '08 on a 130kg lead powered scooter
+1 :wink:Danny Mayes said:Pics????
