I'm a senior and ride a recumbent trike (HPV). I have a rear hub motor and 36v battery. I want to set it up so that at assist level 1 it gives the barest minimum of
assist. I have a 52t chainring because anything smaller leads to ghostpedaling. I've found 2 settings that helped reduce the immediate boost (P3 and C14). Are there other settings I should change? The way it is now I never go past level 2 and mostly always ride in level 1 assist. I just can't spin faster than 70rpm consistently. Would it help to "trick" the system by setting the tire size from 20" to something else? I would like a more graduated assist in the beginining, but I can't use a torque system, because I have Myasthenia Gravis, and at some point in my ride my muscles will bork and pushing will become nearly impossible.
