The resistance of the wire winds determine how much heat the motor produces since amount of heat produced = I^(2)R. How much power the motor can produce is determined by how much heat it can take (eg better cooling, larger size and higher quality parts such as heat resistant magnets etc.) since the amount of power going in is proportional to the current input. As current increases, eventually due to the I^(2)R element, the amount of power wasted as heat becomes significant compared with the useful power output. Hence the kV element is irrelevant in this case, except that a higher resistance winding will derate the power rating due to increased heat generation at higher current.
