tatus1969 said:![]()
Right click to open in new tab
I'd have expected the screws holding the electrode to be towards the bottom of the electrode holder not the top so they can still hold worn electrodes.
eee291 said:Thanks for the correction but I think you know what I meant :wink:
flippy said:eee291 said:Thanks for the correction but I think you know what I meant :wink:
yes, but it would not be as funny.
on a more serious note: higher resistance metals that can take higher temps is a cirular fail as you need more power as the electrodes take up more power then the weld itself so you get even more heat and everything else needs to be bigger and better as well and the only thing you are doing in the meantime is wasting power. lower resistance is arguably the most important metric for electrode choice.
first reason would be that they have "commercial" prices.tomjasz said:why not use electrodes made for commercial welders?
https://sunstonewelders.com/electrodes/
flippy said:first reason would be that they have "commercial" prices.
considering the kweld electrodes are also made from "the right stuff" i doubt you will see any difference with the copper based electrodes. if you want to go hardcore you can get the moly of tungsten electrodes but using them for nickel is not recommended.tomjasz said:The real question is will they perform better?
flippy said:considering the kweld electrodes are also made from "the right stuff" i doubt you will see any difference with the copper based electrodes. if you want to go hardcore you can get the moly of tungsten electrodes but using them for nickel is not recommended.tomjasz said:The real question is will they perform better?
tomjasz said:flippy said:first reason would be that they have "commercial" prices.
$20-$30? My POS dead Sunnko was $250. My new KWeld will be $234.
ElectricGod said:I have another idea:
Why bother welding at all? I already mentioned using some reflow solder paste between the nickel or copper and the cell. As the weld is made, it creates a lot of localized heat. Enough heat to melt solder and short enough duration to NOT heat up the cell. This may be a great way to solder the nickel or copper to the cell without worrying about welds at all.
Thanks, I'm anxious to read the results!ElectricGod said:[
I'm still busy with the closing details of that battery pack build and a controller mod, but I'll soon be reporting what I find out.
That was done deliberately, to create a longer path that the picked up heat can travel before reaching the holder. I have quite a few of these in stock at the moment, therefore not easy to change thatflywire said:I'd have expected the screws holding the electrode to be towards the bottom of the electrode holder not the top so they can still hold worn electrodes.
Never owned a Sunkko, but I can tell that I have quite a few customers who told me that they have dumped their Sunkko after having used kWeld 8)tomjasz said:My POS dead Sunnko was $250. My new KWeld will be $234.
Your results look very promising! One remark that matches your observations: solder paste contains not only flux but also chemicals that remove corrosion, which is why the recommended reflow profile usually starts with a preheating period at a lower temp like 150degC. This allows these chemicals to remove corrosion from the SMD components and the PCB pads, before raising the temp to the reflow level. As this isn't possible in the short welding time here, it explains to me why you found sanding necessary.ElectricGod said:I was super curious to see how well solder paste would augment a spot weld
That 8.75 milliOhm reading seems to be way too high to my 'electrical intuition'. I assume that your meter uses 4-terminal measurement, right? If that is the case, then I would use the two clips for the current terminals, but solder the voltage sensing leads directly to the nickel strips.ElectricGod said:Notice the positions of the alligator clamps out on the ends of the 1" sections of .15mm nickel. I want all possible variables to be minimized. That's .00875 ohms.
A miserable experience.tatus1969 said:Never owned a Sunkko, but I can tell that I quite a few customers who told me that they have dumped the Sunkko after having used kWeld 8)tomjasz said:My POS dead Sunnko was $250. My new KWeld will be $234.
tomjasz said:A miserable experience.tatus1969 said:Never owned a Sunkko, but I can tell that I quite a few customers who told me that they have dumped the Sunkko after having used kWeld 8)tomjasz said:My POS dead Sunnko was $250. My new KWeld will be $234.
Would you mind commenting on probes. I imagine somewhere in the thread you have, but I''m at a loss finding that. Are any of these materials a potential improvement? https://sunstonewelders.com/products/welding-electrodes/
Thank you!
tatus1969 said:Your results look very promising! One remark that matches your observations: solder paste contains not only flux but also chemicals that remove corrosion, which is why the recommended reflow profile usually starts with a preheating period at a lower temp like 150degC. This allows these chemicals to remove corrosion from the SMD components and the PCB pads, before raising the temp to the reflow level. As this isn't possible in the short welding time here, it explains to me why you found sanding necessary.
tatus1969 said:That 8.75 milliOhm reading seems to be way too high to my 'electrical intuition'. I assume that your meter uses 4-terminal measurement, right? If that is the case, then I would use the two clips for the current terminals, but solder the voltage sensing leads directly to the nickel strips.
"...would you mind commenting on probes. I imagine somewhere in the thread you have, but I''m at a loss finding that. Are any of these materials a potential improvement?..."
tatus1969 said:Never owned a Sunkko, but I can tell that I have quite a few customers who told me that they have dumped their Sunkko after having used kWeld 8)tomjasz said:My POS dead Sunnko was $250. My new KWeld will be $234.
garolittle said:I am one of those who dumped the Sunkko after using the kWeld. 8)
