john61ct said:BBQ gloves, can handle live coals
Murphy got you, because that's a 6k57 0.1% precision resistor, which you most likely don't have in your drawer That's part of the internal voltage reference generation and must be that exact value and precision. The resistor connects to that third IC pin from the left, and to R32 right to it (directions according to your picture).ElectricGod said:tore off the resistor at R31. Looking at the other board it is labeled 657 or 650,000,000 ohms or 650 meg ohms, but that seems unlikely.
tatus1969 said:Murphy got you, because that's a 6k57 0.1% precision resistor, which you most likely don't have in your drawer That's part of the internal voltage reference generation and must be that exact value and precision. The resistor connects to that third IC pin from the left, and to R32 right to it (directions according to your picture).ElectricGod said:tore off the resistor at R31. Looking at the other board it is labeled 657 or 650,000,000 ohms or 650 meg ohms, but that seems unlikely.
ElectricGod said:lol...figures...the one resistor of an impossible to scrounge value...
That's awesome! Curious to see how that welds.ElectricGod said:check out that .1mm thick alloy! Not much more resistance despite being 1/3rd as thick.
tatus1969 said:That's awesome! Curious to see how that welds.ElectricGod said:check out that .1mm thick alloy! Not much more resistance despite being 1/3rd as thick.
ElectricGod said:It's nickel, stainless steel and copper. I asked if he could send me a sample of it so he sent me 12" of it. He has no supply yet so this with a lot of his very limited stock.
As expected the .3mm nickel has the lowest resistance. But check out that .1mm thick alloy! Not much more resistance despite being 1/3rd as thick. This alloy is supposed to have significantly less resistance thanks to the copper content than pure nickel and not oxidize or corrode like copper thanks to the SS and nickel.
ElectricGod said:.15mm = 50 joules
.3mm = 100 joules
So I'm guessing I need 30-40 joules for the .1mm alloy. But then since it is part copper and SS...who knows!
I've never welded .3mm before. It takes a lot of energy to get decent welds and even then they are not as strong as the .15mm welds. 50 joules and .15mm dies not come apart without pliers. .3mm can be broken off the cell with some semi aggressive wiggling. I tried all the way up to 300 joules last night and that didn't seem to improve the strength over 100 joules. Maybe a single super cap module is unable to provide the current needed?
Exactly!ossivirt said:ElectricGod said:.15mm = 50 joules
.3mm = 100 joules
I think that when you get to the 0.3mm nickel or to pure copper it is important to have lots of current. Even when energy is constant it makes some difference if the 50joules is delivered in 50 or 100ms pulse. I have also noticed that after certain point more joules don't chance results. I assume that is because weldtime gets so long that it just starts to spread the heat to larger area..
tatus1969 said:Exactly!ossivirt said:ElectricGod said:.15mm = 50 joules
.3mm = 100 joules
PaulD said:ElectricGod said:It's nickel, stainless steel and copper. I asked if he could send me a sample of it so he sent me 12" of it. He has no supply yet so this with a lot of his very limited stock.
Sounds like EMS SigmaClad : https://www.emsclad.com/solutions-by-sector/energy-storage.html
I'm assuming it's clad, not an alloy. If so, it's been around for a while, but a bit expensive. It's used in less cost sensitive high power stuff. It welds nicely considering it's conductivity due to the stainless layers.
If you feel like you need to. 2000 amps is the max allowed but some naughty people have gone over it and for some reason I think you will try it too :lol:. Calibration will not be possible at over 2000 amps but I hear it still welds..ElectricGod said:tatus1969 said:Exactly!ossivirt said:ElectricGod said:.15mm = 50 joules
.3mm = 100 joules
I have current set to 900 amps. So... go higher?
Who regulates, in what jurisdiction?ossivirt said:If you feel like you need to. 2000 amps is the max allowed
ossivirt said:If you feel like you need to. 2000 amps is the max allowed but some naughty people have gone over it and for some reason I think you will try it too :lol:. Calibration will not be possible at over 2000 amps but I hear it still welds..
Maybe allowed is wrong word but 2000 is the number in the manual. That is maximum that the unit is designed to handle.john61ct said:Who regulates, in what jurisdiction?ossivirt said:If you feel like you need to. 2000 amps is the max allowed
Physics does, as well as the welder's current measurement and protection :wink:john61ct said:Who regulates, in what jurisdiction?ossivirt said:If you feel like you need to. 2000 amps is the max allowed
