Here is a crazy question for kWeld's creator, Mr. T.
I recently bought a new AGM battery and both of my kWelds units complain of overcurrent when I try to calibrate them.
If I swap the battery and electrode cables with thinner ones, I am able to successfully calibrate them but I know I am getting too close to the upper limit of the juice these great welders can handle, not to mention, I am not able to use all the energy this battery can produce.
So I got to think, what if I buy a solid sate relay really beefy and somehow add it to the mix, either by bypassing the MOSFETs or adding its capacity to the kWeld. This way I would have plenty of headroom in terms of current-handling capability.
This is the one I had in mind (or perhaps a different one would be better) because when you read the specs, it is one of the biggest available in that price range.
https://www.mouser.com/ProductDetail/558-HDC200D160H
The datasheet claims a "Maximum Surge Current (10ms) [Adc]" of 1600:
https://www.mouser.com/datasheet/2/657/hdc-series-dc-panel-mount-1370829.pdf
Is this even remotely doable?
I am OK with gutting one of my welders for testing this. I can always buy a new one to replace it if it dies in the operating table.
Doing this kind of experimentation is in part why I got into building my own battery packs and really enjoy modifying and optimizing my tools.
