latecurtis
what is the real deal with these. are all lead acid batteries the same or are some better than others when it comes to weight
per Ah. I have a 24 volt currie ezip trailz. hobby king has cheap lipos but they are rated in millAhs. converted th Ah the biggest single battery is 8000 or 8Ah. its also around $100 for one. the 4s 5000s may be only $23 dollars each but will need 8 of them to get 20Ah and will be incompatable for my controller as it exeeds the max cutoff volts. the 8s for about $100 is 25.9 volts and will work but will need two just to equel 16Ah. three for 24Ah which is what I need.
lead acid is a much better option. two 12 volt 22Ah or better. I will mount them on the lower crossbar of my triangle with gorilla tape. I already tried it with two 12 volt toy batt. one was 7Ah the other 8Ah. I wired them in series to the controller then wired each of them in parrell to the two beat 12 volt 10Ah beat batteries i ripped out of the currie case. I had to solder the connectors on the one currie as they were broke off and flush with the top of the battery. I soldered the wires and taped them. this all charged up and worked. but not much better than the curries. all these batteries are beat. I need two good ones on the crossbar. please let me know where to get them. they cant be over 3 inches wide so i can gorilla tape them in.
