I got these as a random find a few days ago:
http://www.endless-sphere.com/forums/viewtopic.php?p=306463#p306463
and took them home because I have been pondering whether sections of skis could be used as leaf springs, either single- or double-ended, for at least a trailer if not a bike or trike, for a pretty long time. It just wasnt' worth actually buying any of the sets I see at thrift stores, because they are usually either beat up pretty bad if they're in the $5 range, or else they are $15-$50, sometimes *each*.
Plus almost all of them have holes drilled thru for the boot mounts. These don't have any holes yet. And they're hot pink, if I need visibility from them for some reason. :lol:
I know they can take a lot of abuse and flex in general, as I've seen some skiers take bad flips, falls, and rolls, as well as some horrendously bad landings from jumps that started with the point of the ski and bending it up nearly into a J without breaking. Haven't actually tried bending these very far yet, because I want to preserve them for the actual experiments of suspension.
I'm thinking the first place to try them is on the kennel trailer, which would be the easiest one to modify. I'd just need to make a wooden block or bar across the center of the leaves left and right, to bolt the wheel-mount plates to. Then secure the leaves to that block, and to the trailer flatbed and/or frame.
If everything works as expected, I could then fabricate steel or aluminum parts to replace the wood, but I don't want to do all that work unless it at least seems to function as desired.
I assume I will have to fix the ends so the ski section I'd be using goes into the curve of a bow, pointed upward at the ends and down at the middle, so that the bow is in compression and acts like a spring by bowing out the curve on either side of the center while the center travels upward?
This ought to be fairly simple to do. I'm not sure if I would be better off using the thinner front end of the ski or the thicker middle or so-so rear. I am thinking that it should be the thinner part, so it has more give as a bow shape. I then could try the thicker part later as a half-leaf shape, with the axle near it's lowest end. That one I don't expect to work. The first *should* but depends on teh springiness and strength of the ski.
I'm hoping it works well enough that I can try making a leaf suspension for the rear of a bike, although I expect that could get complicated, the way I am visualizing it.
Anybody ever tried this before, with skis?
