a] calibrate hall sensors
b] determine coil positions
c) PWM parameters
d) current settings
e) control loop parameters
f) throttle setup
g) running modes
h) CAN bus setup
i) Field Oriented Control
z) store parameters in EEPROM for motor use
------> d
a) number of current sensors: 3
b) current sensor transimpedance: 10.00 mV/A
c) maximum motor phase current: 59.9 A
d) maximum battery current, motor use: 59.9 A
e) maximum battery current, regen: 29.9 A
f) maximum shutdown error current, fixed: 14.9 A
g) maximum shutdown error current, proportional: 14.9 A
h) IIR filter coefficient, throttle current: 3
i) IIR filter coefficient, error current: 10
j) use additional comb filter: YES
k) use offset calibration: YES
l) restore default calibration
z) return to main menu
------> l
default values restored
------> z
# (c)opyright 2012, B.M. Putter #
# Adliswil, Switzerland #
# bmp72@hotmail.com #
# version 1.1 #
# experimental, use at your own risk #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> e
a) loop sample frequency: 38.01 kHz
b) 1st order phase loop integrator coefficient: 65535.9999
c) 2nd order phase loop integrator coefficient: 65535.9999
d) amplitude loop integrator coefficient: 65535.9999
e) maximum amplitude: 100 %
------> b
new value -> 32.326135
b) 1st order phase loop integrator coefficient: 32.3260
------> c
new value -> .106480
c) 2nd order phase loop integrator coefficient: 0.1063
------> d
new value -> 1.33589
d) amplitude loop integrator coefficient: 1.3357
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
a) write variables to EEPROM
b] reverse direction and write variables to EEPROM
------> a
Data stored in EEPROM for motor use
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> f
a) calibrate throttle 1
b) calibrate throttle 2
c) polynomial coefficients throttle 1 (x, x^2, x^3): 1.0000, 0.0000, 0.0000
d) polynomial coefficients throttle 2 (x, x^2, x^3): -0.0002, -0.0002, -0.0002
e) use analog throttle 1: YES
f) use analog throttle 2: NO
receive throttle over CAN: NO
g) TX throttle over CAN: NO
h) test throttle
------> a
close or hold slight open throttle 1 for offset measurement
press any key to begin measurement
measured voltage: 1134 mV
fully open throttle 1
measured voltage: 4366 mV
h) test throttle
------> h
2 1 F - 0 X
2 | F - X +
2 | F - X +
2 | F - 0X +
21 | F - 0X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 F - 0 X+
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 F - 0 X
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
2 1 | F - 0 X +
21 | F - 0 X +
2 | F - 0X +
2 | F - X +
h) test throttle
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> a
a] number of e-rotations: 20
b] calibrate hall positions
c] table out hall signals
z] return to main menu
------> b
Spin the motor then press any key to start measurement
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> b
a] number of back-emf samples: 1000
b] calibrate coil positions
c] use only fundamental sine waves
d] reconstruct waveforms based on extracted parameters
e] table out data arrays
------> b
Sampling...
coil position capture failed
------> b
Sampling...
------> b
Sampling...
------> b
Sampling...
------> b
Sampling...
------> b
Sampling...
------> b
Sampling...
------> b
Sampling...
------> b
Sampling...
------> b
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> a
new value -> 500
a] number of back-emf samples: 500
------> b
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> b
Sampling...
coil position capture successfull
data arrays now contain sampled back-emf waveforms
------> e
data A, data B, data C
.9884 .9869 .9809
.9884 .9869 .9809
.9884 .9869 .9809
.9899 .9884 .9824
.9899 .9869 .9809
.9884 .9869 .9809
.9884 .9854 .9809
.9884 .9869 .9809
.9899 .9854 .9809
.9884 .9869 .9809
.9884 .9869 .9809
.9884 .9854 .9809
.9869 .9869 .9809
.9884 .9854 .9809
.9884 .9854 .9809
.9884 .9839 .9809
.9884 .9869 .9809
.9884 .9869 .9809
.9884 .9869 .9809
.9884 .9854 .9809
.9884 .9854 .9809
.9869 .9854 .9809
.9899 .9869 .9824
.9899 .9869 .9809
.9914 .9854 .9809
.9899 .9869 .9809
.9899 .9854 .9794
.9869 .9869 .9809
.9884 .9869 .9809
.9914 .9884 .9824
.9884 .9869 .9809
.9899 .9869 .9809
.9899 .9869 .9809
.9884 .9869 .9809
.9899 .9854 .9809
.9869 .9854 .9809
.9899 .9869 .9809
.9869 .9869 .9809
.9869 .9869 .9809
.9899 .9869 .9809
.9884 .9869 .9809
.9899 .9869 .9809
.9884 .9854 .9809
.9884 .9854 .9809
.9869 .9854 .9809
.9869 .9854 .9794
.9899 .9869 .9824
.9869 .9824 .9794
.9869 .9854 .9809
.4949 .4919 .4904
.4949 .4919 .4904
.9884 .9884 .9824
.9914 .9884 .9824
.9869 .9839 .9779
.9899 .9854 .9794
.9914 .9869 .9809
.9884 .9854 .9809
.9869 .9869 .9809
.9914 .9854 .9809
.9899 .9869 .9809
.9899 .9884 .9824
.9899 .9869 .9809
.9884 .9854 .9794
.9899 .9869 .9809
.9869 .9869 .9809
.9884 .9869 .9809
.9884 .9854 .9809
.9884 .9854 .9809
.9899 .9869 .9809
.9884 .9854 .9794
.9869 .9869 .9809
.9869 .9869 .9809
.9899 .9854 .9809
.9869 .9869 .9809
.9884 .9854 .9809
.9884 .9869 .9809
.9869 .9869 .9809
.9929 .9869 .9809
.9884 .9869 .9809
.9899 .9854 .9809
.9914 .9869 .9809
.9899 .9869 .9809
.9884 .9839 .9809
.9899 .9869 .9809
.9914 .9854 .9809
.9884 .9854 .9809
.9899 .9854 .9809
.9914 .9869 .9809
.9884 .9839 .9809
.9884 .9854 .9794
.9884 .9869 .9809
.9884 .9854 .9809
.9914 .9869 .9809
.9884 .9854 .9809
.9869 .9824 .9794
.9899 .9869 .9809
.9884 .9869 .9809
.9869 .9839 .9794
.9899 .9869 .9809
.9899 .9869 .9824
.9869 .9869 .9809
.9869 .9854 .9809
.9884 .9854 .9809
.9869 .9854 .9794
.9884 .9869 .9824
.9869 .9839 .9794
.9899 .9869 .9809
.9884 .9869 .9809
.9884 .9839 .9809
.9884 .9869 .9809
.9899 .9854 .9794
.9869 .9869 .9809
.9884 .9854 .9809
.9884 .9869 .9809
.9914 .9869 .9809
.9899 .9869 .9809
.9899 .9869 .9809
.9899 .9839 .9794
.9899 .9854 .9809
.9899 .9869 .9809
.9884 .9854 .9809
.9884 .9854 .9809
.9899 .9854 .9794
.9884 .9869 .9809
.9899 .9854 .9809
.9884 .9869 .9809
.9899 .9854 .9809
.7402 .7387 .7357
------> a
new value -> 1000
------> b
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> a
new value -> ]50
a] number of back-emf samples: 4550
------> a
new value -> 500
------> b\
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> e
.3530 .8656 .9235
.3530 .8791 .9093
.3530 .8926 .8958
.3522 .9029 .8815
.3522 .9156 .8656
.3530 .9251 .8513
.3522 .9323 .8299
.3522 .9362 .8037
.3530 .9394 .7760
.3530 .9426 .7466
.3530 .9473 .7172
.3522 .9529 .6903
.3507 .9569 .6617
.3515 .9584 .6339
.3499 .9561 .6038
.3507 .9521 .5728
.3522 .9513 .5419
.3499 .9489 .5117
.3491 .9465 .4840
.3499 .9442 .4602
.3491 .9410 .4371
.3507 .9362 .4181
.3507 .9267 .3943
.3586 .9156 .3665
.3760 .9196 .3554
.4006 .9275 .3522
.4292 .9402 .3515
.4562 .9481 .3522
.4848 .9521 .3522
.5181 .9537 .3522
.5514 .9561 .3522
.5879 .9600 .3522
.6212 .9640 .3530
.6546 .9656 .3522
.6847 .9648 .3522
.7141 .9608 .3515
.7434 .9577 .3522
.7728 .9553 .3530
.8005 .9537 .3522
.8251 .9521 .3522
.8466 .9489 .3530
.8640 .9434 .3530
.8759 .9307 .3515
.8878 .9164 .3515
.9013 .9021 .3522
.9124 .8886 .3530
.9227 .8735 .3522
.9299 .8537 .3507
.9386 .8307 .3530
.9402 .8029 .3515
.2412 .2023 .0872
.9418 .7744 .3515
.9450 .7474 .3522
.9489 .7180 .3522
.9521 .6879 .3515
.9553 .6585 .3507
.9577 .6323 .3515
.9553 .6006 .3499
.9537 .5697 .3491
.9513 .5395 .3499
.9513 .5117 .3507
.9481 .4840 .3491
.9442 .4594 .3499
.6990 .3332 .2618
.9299 .4173 .3499
.9180 .3935 .3499
.9069 .3689 .3546
.9085 .3570 .3681
.9212 .3554 .3943
.9307 .3554 .4189
.9378 .3546 .4459
.9410 .3530 .4736
.9434 .3530 .5046
.9481 .3546 .5395
.9537 .3546 .5736
.9577 .3530 .6046
.9624 .3538 .6371
.9616 .3538 .6665
.9608 .3538 .6958
.9584 .3538 .7244
.9584 .3554 .7553
.9577 .3538 .7831
.9569 .3538 .8109
.9561 .3538 .8331
.7077 .2650 .6307
.9505 .3538 .8720
.9410 .3530 .8862
.9283 .3522 .9013
.9172 .3538 .9156
.9021 .3530 .9291
.8854 .3530 .9410
.8664 .3530 .9497
.8426 .3546 .9561
.8085 .3530 .9584
.7783 .3522 .9600
.7442 .3530 .9648
.7109 .3515 .9703
.6768 .3499 .9727
.6466 .3522 .9751
.6125 .3515 .9711
.5792 .3507 .9680
.5458 .3499 .9680
.5165 .3522 .9664
.4871 .3499 .9616
.4602 .3507 .9577
.4340 .3507 .9481
.4070 .3499 .9346
.3816 .3522 .9227
.3641 .3618 .9172
.3554 .3816 .9219
.3530 .4094 .9307
.3530 .4364 .9378
.3530 .4689 .9450
.2650 .3665 .7077
.3530 .5125 .9481
.3522 .5284 .9458
.3522 .5689 .9505
.3522 .6038 .9545
.3522 .6347 .9569
.3522 .6641 .9577
.3530 .6942 .9577
.3507 .7228 .9545
.3522 .7521 .9537
.3515 .7815 .9521
.3530 .8101 .9505
.3522 .8323 .9481
.3522 .8545 .9418
.3522 .8696 .9346
------> d
data arrays now contain reconstructed back-emf waveforms
------> e
-.5577 .5234 .6500
-.5475 .5606 .6349
-.5453 .5879 .6117
-.5514 .6055 .5793
-.5643 .6154 .5376
-.5820 .6197 .4870
-.6014 .6213 .4288
-.6196 .6223 .3647
-.6340 .6250 .2971
-.6428 .6303 .2282
-.6455 .6383 .1598
-.6426 .6484 .0933
-.6356 .6592 .0296
-.6265 .6689 -.0309
-.6177 .6761 -.0890
-.6108 .6794 -.1450
-.6071 .6784 -.1997
-.6065 .6734 -.2538
-.6084 .6655 -.3074
-.6107 .6560 -.3604
-.6113 .6469 -.4120
-.6075 .6397 -.4610
-.5970 .6357 -.5065
-.5782 .6353 -.5469
-.5504 .6386 -.5812
-.5135 .6445 -.6090
-.4685 .6521 -.6302
-.4169 .6595 -.6452
-.3603 .6657 -.6550
-.3004 .6697 -.6607
-.2384 .6713 -.6639
-.1751 .6708 -.6656
-.1106 .6693 -.6667
-.0447 .6677 -.6677
.0226 .6676 -.6686
.0918 .6693 -.6691
.1622 .6735 -.6687
.2328 .6792 -.6669
.3017 .6851 -.6631
.3665 .6889 -.6574
.4244 .6883 -.6502
.4731 .6805 -.6420
.5104 .6637 -.6340
.5354 .6364 -.6274
.5483 .5986 -.6231
.5507 .5511 -.6219
.5453 .4956 -.6242
.5357 .4350 -.6298
.5258 .3720 -.6379
.5192 .3092 -.6476
.5186 .2490 -.6575
.5256 .1925 -.6663
.5402 .1400 -.6731
.5609 .0905 -.6772
.5851 .0425 -.6786
.6093 -.0057 -.6776
.6300 -.0565 -.6750
.6443 -.1108 -.6718
.6499 -.1693 -.6689
.6463 -.2315 -.6669
.6344 -.2958 -.6657
.6163 -.3600 -.6648
.5950 -.4211 -.6632
.5744 -.4763 -.6589
.5576 -.5234 -.6501
.5474 -.5608 -.6350
.5452 -.5879 -.6118
.5512 -.6056 -.5795
.5642 -.6155 -.5378
.5818 -.6198 -.4872
.6012 -.6213 -.4289
.6194 -.6224 -.3649
.6338 -.6250 -.2973
.6426 -.6304 -.2283
.6453 -.6384 -.1600
.6424 -.6485 -.0935
.6354 -.6593 -.0298
.6264 -.6690 .0308
.6175 -.6762 .0888
.6106 -.6795 .1449
.6069 -.6785 .1996
.6064 -.6735 .2537
.6082 -.6656 .3073
.6106 -.6561 .3603
.6111 -.6470 .4118
.6073 -.6398 .4609
.5969 -.6358 .5063
.5781 -.6355 .5467
.5502 -.6387 .5811
.5133 -.6447 .6089
.4683 -.6522 .6301
.4167 -.6597 .6451
.3601 -.6658 .6549
.3003 -.6699 .6606
.2383 -.6715 .6638
.1750 -.6710 .6655
.1105 -.6694 .6666
.0447 -.6679 .6676
-.0227 -.6677 .6685
-.0919 -.6695 .6691
-.1624 -.6736 .6687
-.2330 -.6793 .6668
-.3018 -.6852 .6630
-.3666 -.6891 .6573
-.4246 -.6884 .6501
-.4732 -.6807 .6419
-.5105 -.6638 .6339
-.5355 -.6366 .6273
-.5484 -.5988 .6229
-.5508 -.5512 .6218
-.5455 -.4958 .6241
-.5358 -.4352 .6296
-.5259 -.3721 .6377
-.5193 -.3094 .6474
-.5187 -.2492 .6573
-.5257 -.1927 .6661
-.5403 -.1401 .6729
-.5610 -.0906 .6770
-.5852 -.0426 .6784
-.6094 .0057 .6774
-.6301 .0564 .6748
-.6444 .1107 .6717
-.6500 .1692 .6687
-.6464 .2314 .6667
-.6344 .2958 .6655
-.6163 .3599 .6646
-.5951 .4210 .6630
-.5744 .4762 .6587
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> za
------> a
------> za
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> i
a) use Field Oriented Control: YES
Before automatic measurement of the motor parameters
the controller must be supplied with the same voltage
as in the vehicle. PWM frequency and deadtime must be
initialised. ADC's must be properly set up and calibrated
or calibration must have been restored to default.
The following parameters must be set at their final value:
b) amplitude measurement current: 29.9 A
c) impedance measurement frequency: 37.97 k-erpm
d) determine motor impedance
e) battery voltage (for inductance display only): 81 V
measured inductance (star configuration): 130.1 uH
------> a
a) use Field Oriented Control: NO
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> za
------> a
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> [00][00][00][00][00][00][00]
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> a
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> d
------> h
new value -> 5
h) IIR filter coefficient, throttle current: 1
------> i
new value -> 3
i) IIR filter coefficient, error current: 3
------> h
new value -> 7
------> h
new value -> 2
h) IIR filter coefficient, throttle current: 2
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> [00][00]
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> a
------> b\
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> b\
------> b
Sampling...
------> b
------> b
Sampling...
------> b\
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> b
Sampling...
------> b\
Sampling...
------> b
Waiting for motor to slow down
Sampling...
------> b\
Sampling...
------> e
-.9634 -.5961 -.5559
-.9594 -.5807 -.5606
-.9553 -.5666 -.5632
-.9547 -.5572 -.5720
-.9594 -.5518 -.5854
-.9634 -.5485 -.6002
-.9688 -.5465 -.6183
-.9708 -.5451 -.6371
-.9708 -.5431 -.6566
-.9728 -.5424 -.6801
-.9755 -.5411 -.7029
-.9775 -.5397 -.7257
-.9795 -.5377 -.7445
-.9822 -.5404 -.7687
-.9822 -.5404 -.7888
-.9815 -.5411 -.8090
-.9782 -.5397 -.8278
-.9788 -.5418 -.8499
-.9782 -.5418 -.8687
-.9782 -.5424 -.8862
-.9761 -.5424 -.9023
-.9735 -.5444 -.9171
-.9627 -.5451 -.9359
-.9500 -.5465 -.9520
-.9365 -.5451 -.9607
-.9224 -.5418 -.9661
-.9070 -.5404 -.9708
-.8895 -.5397 -.9735
-.8694 -.5384 -.9748
-.8459 -.5391 -.9755
-.8211 -.5371 -.9761
-.7976 -.5371 -.9768
-.7754 -.5364 -.9768
-.7546 -.5377 -.9768
-.7324 -.5364 -.9755
-.7096 -.5377 -.9735
-.6875 -.5371 -.9688
-.6680 -.5391 -.9688
-.6478 -.5384 -.9654
-.6311 -.5404 -.9667
-.6123 -.5397 -.9614
-.5988 -.5431 -.9580
-.5827 -.5438 -.9520
-.5679 -.5471 -.9439
-.5579 -.5559 -.9419
-.5498 -.5659 -.9426
-.5491 -.5820 -.9466
-.5478 -.5995 -.9513
-.5471 -.6170 -.9526
-.2732 -.3101 -.4766
-.5465 -.6465 -.9540
-.5465 -.6579 -.9553
-.5465 -.6801 -.9553
-.5465 -.7136 -.9600
-.5458 -.7331 -.9614
-.5458 -.7539 -.9620
-.5471 -.7734 -.9634
-.5458 -.7915 -.9614
-.5485 -.8130 -.9620
-.5471 -.8305 -.9614
-.5485 -.8499 -.9620
-.5478 -.8667 -.9614
-.5485 -.8822 -.9594
-.5485 -.8936 -.9553
-.5498 -.9036 -.9540
-.5512 -.9164 -.9459
-.5518 -.9298 -.9352
-.5505 -.9379 -.9271
-.5518 -.9486 -.9197
-.5491 -.9547 -.9063
-.5512 -.9614 -.8949
-.5518 -.9654 -.8781
-.5498 -.9667 -.8580
-.5505 -.9688 -.8372
-.5485 -.9701 -.8150
-.5478 -.9741 -.7949
-.5458 -.9741 -.7727
-.5471 -.9761 -.7546
-.5465 -.9755 -.7331
-.5485 -.9755 -.7130
-.5471 -.9741 -.6901
-.5471 -.9741 -.6687
-.5471 -.9755 -.6492
-.5478 -.9761 -.6324
-.5478 -.9748 -.6143
-.5491 -.9728 -.6015
-.5538 -.9674 -.5800
-.5592 -.9654 -.5673
-.5693 -.9647 -.5559
-.5854 -.9688 -.5532
-.6035 -.9735 -.5498
-.6237 -.9782 -.5491
-.6445 -.9788 -.5478
-.6693 -.9802 -.5491
-.6935 -.9808 -.5478
-.7197 -.9822 -.5471
-.7438 -.9835 -.5465
-.7660 -.9849 -.5465
-.7895 -.9849 -.5471
-.8110 -.9835 -.5491
-.8318 -.9802 -.5498
-.8533 -.9802 -.5525
-.8707 -.9782 -.5525
-.8895 -.9761 -.5532
-.9043 -.9741 -.5559
-.9164 -.9681 -.5565
-.9258 -.9600 -.5572
-.9372 -.9526 -.5592
-.9426 -.9399 -.5572
-.9506 -.9291 -.5579
-.9573 -.9164 -.5579
-.9620 -.9016 -.5565
-.9620 -.8815 -.5545
-.4793 -.4431 -.2792
-.9661 -.8600 -.5545
-.9661 -.8459 -.5552
-.9667 -.8190 -.5552
-.9674 -.7882 -.5532
-.9681 -.7694 -.5525
-.9694 -.7519 -.5525
-.9681 -.7331 -.5545
-.9667 -.7136 -.5538
-.9661 -.6928 -.5545
-.9654 -.6727 -.5545
-.9654 -.6532 -.5538
-.9654 -.6371 -.5545
-.9641 -.6196 -.5545
-.9614 -.6062 -.5565
------> d
------> e
-.6072 .5156 .6045
-.6032 .5530 .5899
-.6025 .5845 .5697
-.6050 .6102 .5427
-.6101 .6307 .5083
-.6169 .6464 .4661
-.6243 .6585 .4165
-.6310 .6677 .3604
-.6362 .6749 .2989
-.6394 .6806 .2336
-.6408 .6854 .1660
-.6407 .6893 .0975
-.6398 .6923 .0292
-.6391 .6942 -.0380
-.6390 .6949 -.1041
-.6401 .6943 -.1688
-.6421 .6924 -.2321
-.6442 .6895 -.2940
-.6451 .6858 -.3542
-.6434 .6821 -.4123
-.6369 .6790 -.4674
-.6242 .6769 -.5184
-.6039 .6762 -.5641
-.5750 .6773 -.6033
-.5373 .6800 -.6352
-.4913 .6842 -.6592
-.4379 .6894 -.6755
-.3784 .6950 -.6847
-.3142 .7004 -.6880
-.2470 .7052 -.6871
-.1780 .7091 -.6836
-.1082 .7118 -.6792
-.0385 .7135 -.6752
.0307 .7143 -.6723
.0992 .7143 -.6707
.1664 .7136 -.6700
.2319 .7122 -.6695
.2948 .7096 -.6681
.3542 .7054 -.6647
.4087 .6986 -.6585
.4573 .6885 -.6492
.4985 .6738 -.6369
.5317 .6538 -.6224
.5566 .6276 -.6071
.5735 .5952 -.5923
.5834 .5562 -.5796
.5879 .5112 -.5702
.5887 .4610 -.5653
.5881 .4065 -.5650
.5877 .3487 -.5693
.5893 .2889 -.5773
.5935 .2279 -.5876
.6006 .1663 -.5991
.6099 .1047 -.6102
.6205 .0433 -.6199
.6307 -.0178 -.6274
.6394 -.0788 -.6323
.6451 -.1396 -.6348
.6470 -.1999 -.6351
.6451 -.2592 -.6336
.6396 -.3170 -.6310
.6316 -.3726 -.6273
.6226 -.4248 -.6221
.6139 -.4728 -.6149
.6071 -.5158 -.6046
.6030 -.5531 -.5900
.6023 -.5846 -.5699
.6048 -.6103 -.5429
.6100 -.6307 -.5085
.6167 -.6466 -.4664
.6241 -.6586 -.4167
.6308 -.6678 -.3605
.6360 -.6749 -.2990
.6392 -.6807 -.2337
.6406 -.6855 -.1661
.6405 -.6893 -.0977
.6397 -.6924 -.0293
.6389 -.6943 .0379
.6389 -.6950 .1040
.6400 -.6944 .1687
.6419 -.6925 .2320
.6440 -.6895 .2939
.6450 -.6859 .3541
.6432 -.6822 .4122
.6368 -.6790 .4673
.6240 -.6770 .5183
.6037 -.6763 .5640
.5748 -.6775 .6033
.5372 -.6802 .6351
.4912 -.6845 .6591
.4377 -.6896 .6754
.3782 -.6952 .6846
.3140 -.7006 .6879
.2468 -.7054 .6870
.1779 -.7092 .6835
.1081 -.7120 .6791
.0384 -.7137 .6751
-.0309 -.7144 .6722
-.0993 -.7145 .6706
-.1665 -.7138 .6700
-.2321 -.7124 .6694
-.2950 -.7098 .6680
-.3544 -.7055 .6646
-.4089 -.6988 .6584
-.4573 -.6886 .6491
-.4986 -.6740 .6368
-.5318 -.6539 .6224
-.5567 -.6278 .6070
-.5736 -.5953 .5921
-.5835 -.5563 .5794
-.5880 -.5113 .5700
-.5888 -.4612 .5651
-.5881 -.4067 .5648
-.5878 -.3489 .5691
-.5894 -.2890 .5771
-.5936 -.2280 .5874
-.6006 -.1665 .5989
-.6100 -.1048 .6101
-.6205 -.0434 .6198
-.6308 .0178 .6273
-.6395 .0787 .6322
-.6452 .1394 .6346
-.6471 .1997 .6349
-.6452 .2591 .6335
-.6397 .3170 .6309
-.6318 .3725 .6272
-.6227 .4247 .6220
-.6141 .4727 .6148
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> d
------> l
------> a
new value -> 3
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> g
a) sensored or sensorless: SENSORED
b} sensorless startup: SELF START
c} e-rpm limit sensorless self start: 1984
d} e-rpm reached before transition: 85 %
e} minimum current push start: 4.9 A
f} push start current, error allowed: 5 %
g] erpm sensored to sensorless transition: 3000
h] transition time sensored to sensorless: 299 milli-sec
i) return to motor start below 2500 erpm
j) controlled slowdown for direction change: YES
k) phase current for controlled slowdown: 29.9 A
l) motor maximum, forward: 99.97 k-erpm
m) motor maximum, reverse: 99.97 k-erpm
n) motor standstill voltage threshold: 0.39 V
o) enable low side pulsing in drive 0: YES
p) low side pulsing rate: 20 Hz
q) low side pulsing width: 20 usec
------> c
new value -> 200
c} e-rpm limit sensorless self start: 174
d} e-rpm reached before transition: 980 %
------> d
new value -> 87
d} e-rpm reached before transition: 80 %
------> z
# version 1.1 #
c) PWM parameters
d) current settings
f) throttle setup
g) running modes
h) CAN bus setup
------> z
------> a
------> [00][00]
