Dingo2024
Just come across this, not sure it has been looked at here before;
LED "fuel gauge" measures your battery voltage to a few 10ths of a volt! Provides an indication of remaining battery power. Mounting posts and brass screws included. Simple 2 wire hookup. Instructions. Available in 24, 36, and 48 volt versions. YOU supply the housing and mounting method.
about half way down this page;
http://www.evdeals.com/LashoutParts.htm
is this of any use and is it accurate enough to be used as per a regular 'car' fuel gauge; also would it work with all battery chemistry's?
thanks,
Ian
thanks,
Ian
