One reason for failures in a single specific place like that is a design or machining flaw leaving a stress riser there, but I don't see one. If it failed on a different leg of the spider it might be something more general, but if it's that specific leg every time, it probably has to do with the angle that leg joins the ring at, and or the stress riser issue.
If it's different legs each time, I would guess fatigue from flexing sideways cyclicly, from a slightly off-center chainline, such that the chain to the rear sprocket is pulling sideways enough on the chainring at the top of the cycle vs the rest of the rotation that it eventually fractures the spider.
If this is the case, then you can straighten the chainline and eliminate the problem.
(Most of the time I see problems with chainring deformation or damage when middrives (or even high-torque human pedalling) are used with the rear sprocket left shifted into the higher gears for high torque situations, instead of downshifting to the lower gears as the system is designed to be used).
