Patriot
- Joined
- Aug 7, 2008
- Messages
- 511
gwhy! said:chet said:Not for regen. Regen is not practical on bicycle. This uses the motor as a generator through a resistor to slow the wheel. Regen would go to the battery. Whole different thread.What makes you say that regen is not pratical on a bicycle that can travel at 40mph+ . Yes the motor is used as a generator with a load ( resistor ) placed on the end of it , why cant the load be a charging circuit. This thread is about brakes, and using motor braking combined with mechanical braking and I think it makes perfect sence. Maybe not in a primitive form i.e switch for brake on/off, but a proportional brake lever that varies the load on the motor could be a very good way to go.
This is exactly what I have done with my 48v/5303.
I have variable regen through my Kelly controller, using a 5v thumbie on the left handlebar. I use it long decents, and when slowing down from 40mph. I works perfectly. It doesn't stop the bike completely, but it does slow it down nicely to about 10mph where it disengages. I then use my regular brakes to stop.
Using variable regen is a great way to slow down for ebikes, especially when using high speed setups that may otherwise eat up, or burn up lightweight mechanical brakes.
