john61ct said:
So have you had any hands-on with these?
I have used most of those in applications. What doyou want to know?
Would you like to know more?
methods said:
Short Circuit Tester
-methods
That is your SC Current testing machine?
Gee i just use a K-Welder machine on the calibrate setting. Tells me the milliseconds and teh amps up to 2000A. Good voltage ranges for my stuff. Frank said it is a direct measurement of peak SCC and time.
Further calculation is available if you have these informations.
....are you sure your testing machine is " fast enuf'.... ? What about a much more powerful cell that might act differently ( time to make full SCC)..
.... Are you testing the output of the cell... or are you just testing the response time of the BMS? I dont get it. Why not use an oscilliscope for the BMS test. I like to use the SSC test to determine the maximum current the cell will push ( helpful when designing Zipper fuses).
I hear they are fast and accurate. Nowadays. In the measurement of time. Current. Voltage. Such as the like. I mean,, can you not capture and record a short event easily with a scope? Digitally referenced?
If I could afford 800$ of Mosfets i would own the DSO first. Certainly you are skilled with the recording of current and voltage wave forms. With the education you have.
My Tektronik is from 1963. I wish I could afford a real scope.
