k-harvey
My latest purchase of a LiFePo4 charger disappoints me as the voltage for 12v near new pack( 8 cells -4 lots of 2 in parallel )gets to only 13.7 volts where i expected it to reach 14.6 giving greater AH needed for the job. I was previously using my automatic LA car charger(naughty I'm told) & even got a slightly higher voltage.
Could this be that in purchasing the charger from Greenbike i was asked what voltage charger was needed for the 12 volt charger ( I thought they'd know) any way I said the battery packs as 12 volt are supposed to be a max. of 14.6 volt . So chargers usually have a higher voltage than the battery & in this case the charger ,charges at 14.6V.
Is this usual for a 12v pack to have this maxi-min of 13.7 Volts.??(with BMS) Did i dictate what Max.voltage the charger produced.
I'm dis appointed as the car charger seems just as good & got to a higher voltage.
