SOLD [$30 plus shipping, USA BASED] Li-Ion 36V 15.3Ah 551wh (2550mAh cells) 50A ,10s6p, Locked BMS
AmericanElectricSolutions
🔋 Established
Los Angeles
We have about 10 of these. The price for the whole lot is $250
Full specs below:
Condition: Unused, stored in a warehouse. Kept at 50% charge at all times but some degradation is expected due to their age (2 years)
Connector: xt60
Cell Layout: 10 series 6 parallel
Measurements:16.7 x 5.1 x 3.1 inches (423mm×130mm×78mm)
Casing: Plastic
Nominal Voltage: 36V (Max voltage 42v)
Limited Charging Voltage: 42V/3A
Resistance (23 ± 2 ℃): ≤ 250mΩ
Charging time: 4-5 hours
Cycle life: ~800-1000 cycles if used gently, 500-700 if used regularly
Nominal Capacity: 15.3ah
Watt Hours: 551Wh
Minimum wattage output: 500w
Ammount of cells: 60
Cell Size: 18650
BMS: Locked but can be flashed. There are guides online.
Use the operating temperature: Discharge: 0-60 ℃; Charging: 0-45 ℃;
Manufacturer: Ninebot
Does not come with a charger.
