don't quite sneak up on people quite as easily with this kit due to the whine of the motor which maybe is a good thing as it allows me to pass when people know I'm there.
I thought the LR kit was supposed to be quiet and that was the main advantage over the cyclone type mid drive kits ? Efficency of belt drive reduction won't be as good as a planetary gear reduction but i thought it was supposed to be very quiet instead ?
Where does the noise come from ? Motor/belts is something rubbing? You are only running 44v and hence only 42km/h top speed as well , i think the noise gets a lot worse the higher the voltage and rpm you run it so i wounder how loud it will be at higher voltages ?
