As to the bending bracket, add spacers on the shaft between where bracket straddles, use nuts since you would need like 50 or so normal spacers.
As for the throttle cutting out on the CA, could it be your brakes cutting the power? Unhook the brake line and try it then.
Up your watts to 2000 and see how that affects acceleration? Is your cycle analyst set up properly? Throttle out up rate 20 volts, Throttle out down rate 20 volts, Throttle out fast rate 20 volts, Throttle out fast thrash 0.00 amps. Power limit Amp Gain 60, Power Limit Watt Gain 60.
Good Luck.
Good Luck.
