mysterywhiteboy
- Joined
- Jun 1, 2010
- Messages
- 17
Hi
I am a bit of a lipo newbie as far as the RC hobby packs go but I decided to dip my toe in the water and get hold of a few packs.
I have read through a lot of posts here on the board which has helped me make my mind up, so thanks for that!
I ordered 4 of Turnigy 5000mah 6S 25C packs from Hobbyking along with 4 of their 6S 25C battery monitors.
I intend to parallel up the packs in to 2 x pairs then connect them in series for a pack total of 45V 10Ah, I got hold of 4 of the battery monitors
to plug in to the balance leads to warn me of cell low voltage on any of the four packs during discharge, these alarms were so cheap
it makes no sense not to have them.
Lipo Pack
I have also ordered an Etronix 4 channel charger balancer as well which should help keep the packs balanced and charged, there are
a few of these 4 port chargers popping up now, they seem to get favourable reviews with the bonus that all four packs will be charged
at the same time, its not quite as convenient as a single supply charger / bms setup but I only intend to charge once a week tops
as my daily AH use is low typically 2AH or so, that said I wont let it drop below 70% DOD to increase cycle life.
4 port charger
I also picked up a Turnigy watt meter, I already have a watts up meter but liked the fact that the Turnigy one is back lit.
Power watt meter
I think I will go for 2 of Gary's boards in time and connect them to the brake inhibit line on the controller. I am running a crystallite X5
with a 35A controller the old analogue type of board, I don't want super high speed just need the batteries not to sag like my poor old
NIMH pack is now doing, I like 25-30 mph most days (Not bad though it has lasted 4 years and many deep discharges).
Battery Monitor
Can anyone see any issues with my setup? I will of course disconnect the pack for charging and plug all 4 packs in to the charger on
their own.
I am going to cut off all of the Deans and solder on Anderson connectors, I will make a fused harness from that to supply the controller.
Guys that have used the battery monitors on planes have commented that the alarms are quite loud so I should pick them up with the pack
sat just behind me, combining that with checks on the watt meter and weekly balancing I should be ok?
I must say also the Hobbykings service so far has been exceptional! Highly recommend them to folks, I guess that you all knew that
its also amazing the C rate and the size and weight of these packs combined makes my old Point-1 lipo packs look amazingly heavy and bulky
in comparison, for high power e-bikes this looks like the most sensible solution as I didn't like the weight and size and multiple cell connections of LIFE
cells and the ping packs were more expensive and too low C for my application.
Cheers
Dan
Lipo Pack
4 port charger
Power watt meter
Battery Monitor
their own.
Cheers
Dan
