I think somebody broke that link of my backside
I did 2 runs test fitting all the parts and making spacers for things to get perfect alignment and bearing load etc. Got all the parts to fit together like a glove, and everything spinning perfectly free. This is a very low friction drivetrain. With the rotors off the motors to eliminate the cogging drag, this setup spins so freely, it doesn't feel much different than just a normal bicycle chain/sprocket setup.
Things were going great. I was very happy.
I mixed up a batch of artic silver epoxy, and added a drip of loc-tite to all my screws and a drop on each bearing/shaft connection. I began final assembly, and things couldn't have been going better. Both motors were locked on, and I began to press the rotors of the motors into place. Then "TINK", and the shaft freely slides forward... I first thought the rotor slid on, but then I saw my sprocket poking out 3", and saw the empty snap ring groove on the shaft....
RAWRRRRRR!!!!!!!!!
That's the sound I make when I'm less than pleased.
So, I rapidly started to disassemble everything again, wiping off loc-tite from every screw, and removing the thermal epoxys with acetone and a rag. When I get to the snap ring area, I find that the inside edge in a few places has mushed over. Yes, just mushed over, like it was made of silly putty. I have never seen a snap-ring do this before. I put it in my snap ring pliars, and opened it up a bit. Did it spring back? No... It stays sprung. I can crush it back into shape just as easily. I was able to twist it like a pretzel with my fingers.
This was the only mechanical part from the original motors that I didn't replace. Now I know not to trust ANYTHING from these motors. These snap rings are made from anealed mild steel, that seems to have the strength of softened copper.
It was 10:00pm, and no where is open to buy REAL snap-rings, so I spent the last hour wiping all the epoxy and loc-tite clean from things before it hardens. I work 12-16hr shifts for the next few days, so this is going to set-back my completion time by a few days. I'm pretty frustrated. I'm going to hit that snapring with my .50cal desert eagle. It might take me a full clip just to hit the twisted dime sized thing, but it's going down.
