marty
I see two types of lithium batteries. Cylindrical and pouches. Are the ones that sometimes catch on fire the pouch ones? Do the cylindrical cells ever catch on fire?
Reason I ask is I have been experimenting with Makita power tool battery packs. Does any one know of any fires involving these Makita cylindrical cells?
Copy details from:
Konion Makita LiMn battery care and feeding by Doctorbass
Post by Doctorbass » Fri May 06, 2011 2:06 am
http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=27707
Here are their specs:
18650V: ( the most popular for ebikes)
( same as the Sanyo’s UR18650W)
-Voltage range: 3.0 to 4.2V
-Nominal voltage 3.7V
-Capacity: 1500mAh(10C) to 1600mAh(1C)
-Max Discharge C rate: 10C ( 15-16A)
-Max Charge C-rate: 1.5 to 2C depending on the cooling
-Cycle life: 700 cycles to 75% initial capacity ( from BMZ manufacture)
-Cycle life claimed by Makita: 1200 cycles
-Internal resistance 30miliohm per cells
-Released in 2005... still existing in 2011
18650VT:
-Voltage range: 3.0 to 4.1 or 4.2V
-Nominal voltage 3.76V
-Capacity: 1030mAh(10C), 1080mAh, ( 1C) to 1300mAh(0.1C)
-Max Discharge C rate: 15C ( 17-20A)... and 30A for 30 sec
-Max Charge C-rate: 3C depending on the cooling
-Cycle life: 500 cycles to 90% of initial capacity, at 2A discharge ( from BMZ manufacture)
-Internal resistance :initial is 25 miliohm ( 26-28 miliohm of used cells)
-Gravimetric energy94 Wh/kg
Copy details from:
18650VT:
