Older scooter with a 7S 24V battery, possibly an overrated 500W motor (China origin?), possibly an overrated 30A Chinese controller. My 20 amp reliable BMS suggestion was based on twilloug's first post followed by obcd's post. That's right i previously said "reliable" 20A BMS (see last pasted quote). Oh my how he does exaggerate ... "Dead wrong!" ... he's definitely no expert, but neither am me.
twilloug said:
I have an older Scoot-e scooter. 24v scooter. I wad having issues with motor so i decided to buy a new 500w motor off of ebay as well as a controller. Now for the question...the battery is a 7s4p 24v battery from china. It measures 27.5 volts, so it is charged. However when i connect directly to motor, nothing happens. Is my battery not big enough for motor?
And ...
obcd said:
A 20 Amps BMS will limit the current to 20 Amps.
Isn't that a good thing considering twilloug's 7S4P 24V battery? What if it's a cheap Chinese overrated 500W motor? 12mph (on level terrain) may be top speed for twilloug's e-scooter ... does it really require a 40-50A BMS?
obcd said:
It's also important that you check if it's safe to draw 20 - 30 amps from your battery. The fact the BMS was only rated 4 15A could mean you shouldn't load your cell much higher. Just check the brand and type of your battery cells and see how many cells are connected in parallel. Check the datasheet of your cells and you know what your safe discharge rate is. Multiply this with your number of parallel cells and you have your total allowed discharge rate.
twilloug said:
Wouldnt i want a 30 amp bms to match the 28 amp rated motor and 30 amp controller?
I see a lot of 20 amp bms but wouldnt that put me in the same boat?
eMark said:
Not if you have a reliable 20A BMS and healthy battery.
Are you sure your battery is AOK?
BMS and controller don't need to be rated at more than your 28A 500W motor.
My own "reliable 20A BMS" with 20A controller and 750W hub motor draws at most 350W at 12mph up a grade with my 10S5P 36V 10A capacity battery. Agree that we don't know how efficient is twilloug's 500W motor. Thus, some justificaton for a 20A BMS and a 20A controller. Do you want to burn up both battery and motor with a 40-50A BMS and 30A controller? According to obcd's post ...
"A 20 Amps BMS will limit the current to 20 Amps" ... and ...
"is it safe to draw 20-30 amps from your battery" ... implies a reliable 20A controller was sufficient enough for a 7S4P 24V Chinese battery and 500W motor (China origin?).
As far as another battery is there even enuf room on twilloug's older e-scooter? Not a good idea unless both batteries have Grade A cells with same capacity and amp rating? Adding another battery borders on overkill (even if room) unless twilloug's plan is using the e-scooter for commuting some distance or a few hours of recreational enjoyment without taking a break at McDs to recharge.
Bottomline: All twilloug really needed was a reliable 20A BMS to protect his 7S4P 24V battery with hopefully an overrated 30A controller an what may be an overrated 500W motor.
fechter is Right On when he says you don't need to pay more than $20 for a BMS including shipping. Whereas john61ct is grossly over exaggerating when he says i'm "Dead wrong!"
fechter (if you're still here) glad you didn't belittle me for my comment that twilloug could use that 50A (7S 24V) BMS if he ever upgrades to a sporty Sur-ron dirt ebike. Maybe, you didn't catch my tongue-in-cheek ... unless you thought someday he might add another 7S 24V for balance charging when split and then joining together again into a 14S 48V battery for his Sur-ron dirt ebike, but then he wouldn't need a 7S BMS. But not using any BMS is for another thread :wink:
As Wernher von Braun said, “One good test is worth a thousand expert opinions.”
If only we were all experts then there would only be 1,000 opinions ... assuming it was a 'good' test :wink:
