Is that an adjustable parameter ?It looks like Load Compensation performs something similar on grades
It looks like a range from 0 to 1020 milliohms, whatever that equates to, but the description makes it sound like you can adjust the behavior under increasing load.Is that an adjustable parameter ?
I thought that an increased load on a brushed motor would result in an increase in amp draw…up to the limit of the controller or battery, ..whichever is the lower .
I am curious to understand how a brushed motor controller can increase the motor voltage above the max battery voltage ?Load Comp can briefly increase motor voltage up 10V more than Max Motor Voltage setting as needed to help climb obstacles.
Thanks. I don't need a larger motor. I just need more current to the motor I already have. Increasing current Boost Time from 2 to 10 seconds will keep the current boosted all the way up the short, steep hills. It's an easy, free solution!I’m glad you figured it out. Thanks for sharing your progress. I’m learning a few things from this thread![]()
I too am curious how the controller does that. Can anyone explain this? Perhaps the controller has a capacitor?I am curious to understand how a brushed motor controller can increase the motor voltage above the max battery voltage?
Also, Torque, for hill climbing, is determined by amperage rather than voltage (speed) ,..
Please let us know how it works out.
With All do respect, I think you are skirting skin loss territory. You do know that you elevated the vehicle's CoG by installing larger rubber... in addition to increasing it's top speed.I have the 3 wheel version of that scooter, which I prefer (due to a much sharper turning radius). On level pavement, it goes 63% faster than stock due to 38% increased tire diameter AND I removed the speed (rpm) limiter. It's adequately stable with 30 lbs of lead batteries in the floor and careful driving.
My 90 YO father was contemplating similar modifications to his scooter. To curb his enthusiasm, I built him a safer, more suitable platform.
A straight forward conversion that yielded a 65 pound, 12mph grocery getter. The original transaxle was retained, in addition to the OEM coupling to separate into two chunks for ease of loading and transporting. Seat was lowered to 18" and rear track increased 3". A pair of Milwaukee V28 cordless drill batteries in parallel supplied the go juice.
I'm familiar with Mobility Direct & Dakota batteries.You may find this interesting..
LfP is more likely to stay balanced than a pair of AGMs !I'm doubtful that two 12V LiFePo4 batteries in series will stay balanced nor live a long life.
Nice work. Did you by any chance do a 'build thread' on that ?
Thank you...Nice work. Did you by any chance do a 'build thread' on that ?
On my mobility scooter there's 1 charging plugin for a 24V charger that charges two 12V batteries in series. This is my source of concern about batteries balance.LfP is more likely to stay balanced than a pair of AGMs !
A they are also proven to outlive AGMs By a huge margin .
PS.. iwas not suggesting any specific brand of battery, just to show the advantages of LFP over AGM.
www.canbat.com
My Dynamic R series 50A controller is 40A Max for up to 20 seconds + 10A Boost for 0-8 seconds. After 20 seconds it drops down to 25A limit for 30 seconds for motor cooling.
According to the owner's manual...I didn't read the entire thread to see whether this has been covered, but it seems to me that if your controller will tolerate an extra 15V, you can just add another 12V battery in series (or its equivalent) to increase both top speed and torque.
