Kraeuterbutter
- Joined
- Jun 14, 2007
- Messages
- 197
Hi...
i know, here at endless-sphere the world starts with 30Amps/500Watt and more
but maybe these is nevertheless for some of some interest:
in German pedelec-forum there are in the moment many trying to use hub-motor with the crank, for better hill-climbing..
Motor: the little, very light (2.1kg) and small Tongxin, rated with 180Watt
another benefit: it is internal geard something around 10:1
but instead of using normal planetary gears its using roller gears which results in a nearly noisless spinning of the motor
the motor is used best with a controller current limit set to 8-10A so it is not overstressed, and with 36V
the motor is geard by most users sofar with around 2:1 to the crank, so in the end - depending on the used tranny - the torque of the motor is in some cases more than doubled in the low gears of the bike compared to using it directly in the rim
here now some pictures from the German forum, for more details visit the german forum (and translate with google):
http://www.pedelec-forum.de
Bike from vauthech :
selfmade from carbon by him
as well as both bikes, completley build from carbon by his own
and more Pics:
http://www.pedelec-forum.de/forum/attachment.php?attachmentid=3466&d=1256034103
http://www.pedelec-forum.de/forum/attachment.php?attachmentid=3470&d=1256034395
this fully former weighted without electrics and with XTR around 9,2kg (!)
now with the electric setup (but no battery) and the 14gears speedhub from rohloff it weights also only 12.9kg (!)
second Bike:
http://www.pedelec-forum.de/forum/attachment.php?attachmentid=3483&d=1256115834
motor reduced in weight -> only 1.69kg !
weight of the bike including the whole drivetrain (but no battery): 10980g (!)
so with an light bottlebattery its around only 12kg !!
how to do it:
http://www.pedelec-forum.de/forum/attachment.php?attachmentid=3509&d=1256292564
http://www.pedelec-forum.de/forum/attachment.php?attachmentid=3517&d=1256379681
Bike from schwarzwaldächzer:
http://www.pedelec-forum.de/forum/attachment.php?attachmentid=3567&d=1256584379
http://www.pedelec-forum.de/forum/attachment.php?attachmentid=3568&d=1256584403
and more Pics:
second Bike:
how to do it:
