John in CR said:
AJ,
Wait, you managed to turn a noisy 1+kg motor into an under 10kg drive unit. IOW, the single RC motor advantage evaporated. Glad to hear you're getting a 2spd box. Can't wait to hear how that works out. To me that's the biggest thing missing in our arsenal of parts, a 2 or 3 speed tranny that can handle the torque of our motors.
I guess i didn't explain things very clearly appologies, once you add up the chains and steel sprockets of the reduction drive John, the drive unit itself the mounting hardware, the reduction drive cover its more than just the weight of the motor but still less than ~10kg I was being fair and counting reduction drive as part of "rc setup" when really its not essential you can run one stage reduction with one larger rear sprocket (as Thud has done, he uses a Lexan rear sprocket) in which case the weight of a 'rc setup' would be just the motor. If i had to guess i would say it would be in the vicinity of 8-9kilo motor/drive unit chains sprockets and mounting brackets....still lighter
than a big frock and you get to place the motor where you want to get best weight placement for the bikes handling, you
also have the advantage of changing gear ratios John, so no, IMHO the advantage has not 'evaporated' at all, far from it
I can also run on 44v worth of batteries don't need to lug half the weight of the bike in packs to get speed....
And yes i have been wanting the two speed since Thud posted his prototype mounted on his red BMX, 2 speeds i can't express how
grateful i am Thud has made one available for me, it is what i really need up hear in my area, especially towing
my chair up these damn hills I have to go fast if i go slow it smokes things, with a low range gear i can protect
the motor and electronics more.John ...
it's definitely what the frock needs! if the frock had a
mechanical two speed even i could them myself
the whole changing rear wheel size and/or upping battery
voltage as the only means to gain performance doesn't sit well for me.
KiM
