Hi everyone,
I'm working on the design of a 3-phase controller but it fails at full power for a 3 kw motor and low speed (about 100 rpm). At about 60 V and 50 A the controller seems to work well in medium and high speed but at low revs and after a short time (less than 1 minute) any of the low side MOSFET will fail with a short circuit across the 3 terminals. When that happens the controllers short circuit protection seems to work well to avoid a shoot through with the corresponding high side MOSFET.
It has also happened that with the same conditions as before I am able to stop the motor after increasing the load and it seems that everything is fine, but when I check the MOSFETS one of the low side has also died. I understand it must be failed at the same instant the motor stops.
As I said the MOSFET always fail with the three terminals shorted and no signs of burning or smoke. The MOSFET I use are IRFB4410 and the gate is driven through a 10 ohm resistor. The PWM frequency is about 16 kHz and have used slow decay asynchronous and also synchronous trapezoidal control together with Hall sensors.
I would appreciate if anyone have any idea about the type of MOSFET failure and cause. My impression is that it could be an avalanche failure and it may be due to a layout problem.
Any thoughts? Many thanks in advance.
