getzbuzy
Hey everyone,
I'm looking for some advice.
I have a 14s, 15ah li-ion pack, and within the last week my setup has been cutting out. My CA2 will show the voltage dropping quickly, when I release the throttle my regen breaking kicks in and it will power back up. This has never happened in the past 15 months of running this battery pack. It appears that all my connections are ok and nothing is loose, but I haven't given a "thorough" inspection. All seems to be running well regardless of amps drawn, which is typically between 30 and 40, as long as my charge is above 51 volts. However, once I drop below 51 volts, I will randomly loose all power if I let it pull 30amps or more. As long as I stay around 20amps only, it's fine.
The pack uses samsung 25r cells with max continuous current of 40A, and has a "very robust BMS, that can deliver around 40A continuous, but much more for extended bursts."
I use a 40A 12 FET IRFB4110 INFINEON CONTROLLER (MOTOR WITH HALL SENSORS)
I have my CA2 limited to 40Amps.
Currently the pack has 2500 amp hours on it, which would mean it has been "cycled" approximately 167 times since it was purchased in May of 2015. Nonetheless, I've charged it (variably between the 90% charge and the 100% charge) between 300-400 times I would guess. Nearly everyday except during the winter months. The actual battery cycle count on my CA2 has never properly worked.
Cycle Life of the pack is estimated at 500-700 cycles (to 80% Retained) with 100% Charge and 100% discharge cycles. Cycle life is extended (possibly doubled) by charging to 90% and limiting discharge to 90%"
I am hard on my setup. I run full throttle always, but I always pedal a going up hills, as well as when taking off from a complete stop. I always stay within the limitations of the system, which for my setup means I use between 1700 and 2000w in short bursts when accelerating, and usually run continuous between 1000w and 1500w when Im up to speed. I usually pull between 30 and the max 40 amps regardless.
It is also definitely worth mentioning that about 8 months ago I melted my anderson pp connection from the battery to my controller, and I was sent a much more heavy duty connector which I had to solder myself.....and my soldering skills definitely aren't anything amazing.
If my "sub-par" solder job weakened over these last 8 months then maybe it can't handle the high amps???
Any other ideas??
Any insight would be helpful.
Any other ideas??
