A
Anonymous
Guest
It now has a front brake! Got the posts welded on this morning, and scored a cable and housing on my way home this afternoon. I just pieced it all together tonight and i'm ready to start doing some effective stopping, hehe!
I put an SLA pack in there for now, a set of three 12-12's that i'm going to hook up to a solar array. Right now my issue is that i need to charge in parallel and discharge in series, so i need to do some sort of trickery with wires, switches, and a charge controller somewhere on the birdnest of wiring. Eventually though, maybe this week i'm going to start ordering some 18650s and part together a tab welder so i can build a pair of 10s5p packs. The plan is to have a pack discharging and one charging from a 'house' bank of 12v SLA's on the solar controller and use some sort of balance charger for the drive packs. Right now i've got a B6 i use but i'd either need two of them or i'd need to buy/build a 10s charger.
Next up is going to be to mount some sort of sunshade until i can get the real shell built proper and set up with a cooling system. I'll probably do something like a loop of PVC with awning canvas stretched to cover the cockpit and aligned with the airflow as not to be too draggy.
For the shell i'm thinking of building a plywood form of the rough shape, covering with 1" foam panels and carving/sanding the outer contours, curves, naca vents and such as well as support hardpoints, skinning with s-glass and dissolving the foam with acetone. Basically a lost foam mold over a box.
