skeetab5780 said:I don't understand why Luna cycles puts out a frame like this, but they wont sell just a regular looking purpose built 68mm BB MTB looking ebike frame?
I feel like that would be the first thing to start with. Id buy one just because... even if I already had a stealth bomber
jpgey said:100mm is not an issue at all, with a 68mm BB the battery box would be smaller
Chalo said:It is difficult bordering on impossible to get a straight chainline on the Luna cargo bike.
Chalo said:For that bike, I highly recommend the Origin8 DAT-PRO 65 rim. It's wide enough for fatbike tires, but narrow enough for MTB and cruiser tires, and it's way stronger than single-walled or drilled-out fatbike rims. Plus, its slightly narrower size buys you more gearing options on a bike that has built-in limitations in that regard.
As for tires, I recommend a smooth treaded tire of at least 2.25" width: Schwalbe Big Apple, Big Ben, Crazy Bob; CST Cyclops, Maxxis Hookworm, Kenda Kraze, Vee Speedster, Origin8 Captiv8r, or Arisun Big Smoothy. The bigger you go within this range, the more it will cost you in speed and chain clearance.
Chalo said:I believe that either hole can be used for a hose (in from the lever, or out to another caliper) or a bleeder bolt.
jpgey said:Chalo said:I believe that either hole can be used for a hose (in from the lever, or out to another caliper) or a bleeder bolt.
Thanks Chalo, thats what I thought, I will test
jpgey said:jpgey said:Chalo said:I believe that either hole can be used for a hose (in from the lever, or out to another caliper) or a bleeder bolt.
Unfortunately the screws are not the same size, from lever the size is bigger than the bleeder screw
