I am making LWB recumbent and want to install power assist to help me up the hills.
So far I have made the frame:
As you can see from the photo front crankset is LH single chainwheel.
Intermediate bottom bracket has two freewheels on LH side and "normal" front/rear deraileur on RH side.
So far simples , but when I started thinking about motor choice it got a bit more complicated...
I don't want "electric only" moped, I don't want overpowered rocket either.
I would like it to be legal (or thereabout) in UK, where the rule is "maximum continuous rated power which does not exceed 250 watts"
not only because it's legal, but because it makes sense (to me at least).
I can get 3200 watts(max), 60 KV brushless RC motor, but this would be way too much for what I want.
Smaller RC brushless motors with more appropriate power rating have too small shafts and far too high KV to be practical.
It would seem 63mm outrunner is about the smallest sensible choice?
I am not the first to ask similar question:
Best RC motor for lightweight utility bike build
The lightest low KV RC-motor for 500w middrive
but I haven't found real answer...
And if I choose 63mm RC motor as above, can I run it at half or one third of it's power to get what I want?
Will it not defeat the objective of using RC motor by destroying it's efficiency? (If I get it right, they are best at around 75% of their max power)
So, any suggestions would be appreciated - thank you.
