matthewalexhart said:
Im replacing the stator on a Mac motor. It came with the copper coil wires unterminated into Phases, just 6 bare copper wires.
I'm unsure exactly what you have / see, as both of the pictures you've included (original and replacement) show motors with stubs of phase wires hanging off the winding connections (the one with the axle also has what appear to be new but damaged phase wires). (I attached the two pictures to my post in case they disappear from yours for any reason, for reference.)
If the phase wires shown are what is being used, and there is any other insulation damage beyond what can be seen in the picture, that allows the conductors to touch either between phases or from them to the hall signal or power wires, etc, it could damage the controller such that it wouldn't be able to correctly drive any motor anymore.
I have used the old stator as a reference for the termination, alas when powered up , just a 1/10 of a turn when a hit the throttle.
Did the old motor work correctly on the same controller? If not, what were the exact specific problems it had that led to it's replacement?
Are boht the phase and hall connections identical not in color, but in connection pattern, to the original setup? If only color was matched, but connection order is different, it's not the same pattern to the controller and it can't drive the motor correctly.
How do a properly test to make sure ive got the right connections?
I can use a volt meter, barely!
If the ones you've connected come from the exact same teeth / etc as the old one has connected, they're probably correct. It's unlikley they'd terminate them in different spots for the same stator type and winding variation (assuming it's the same speed version of the motor, etc).
If you disconnect the terminations, so you have just the separate windings, you can verify with a multimeter set to 200ohms or continuity or diode test ->| - to match ends of winding sets. Assuming a non-shorted stator/winding set, you'll only get a reading between ends of the same winding, so one isolated end will only read across to the other end of the same winding, and not to any of the other four possible ends. It still doesn't tell you which ends to tie together, but it ensures you are connecting them in the necessary pairings to get current flow between them.
