Advice needed. Bike stored indoors for winter. Went out for first ride then battery died. Battery showing 1bar on KD21 display. Pressed battery level indicator. ,showed full charge. Removed battery and observed slight corrosion between the 4 terminals. Checked battery voltage 42+ . Cleaned terminals and replaced battery. Still 1bar and full volts.
Laid bike on side and opened throttle and bike runs at full speed no load.
Read up on such like problems and suggests battery BMS issue/ protect circuit triggered. (Due to leakage across terminals)
One theory was to reset BMS by running the battery down to reset.
Taped full throttle and let run 30miles. Run out of time and patience and recharged battery - only took 1hr to charge.
Same result no power to drive load, no prob no load.
Now here where I have the problem - can’t find the BMS or computer/ controller.
Opened both ends of battery (JZZ LXD BW , 36v 10A 360wh 15A ) - everything covered with black sealant.
Now this is where I get confused ,outside of the battery no sign of computer/controller so am I right in saying everything is contained within the battery?
Is it safe to cut away to reveal the inners or should I conclude it’s a lost cause and replace battery,
My research seems to suggest the Escute is a similar model to the Macwheel and the battery identical??
Can anyone comfirm. If so are Escute issues similar.?
Macwheel is an Amazon brand as I understand and is no longer produced or supported.
Any advice or recommendations will be very much appreciated to get the bike back on the road or !!!!!!???????
