making q85 work
vvvv
Recently I bought cute q85 and S-KU63 controller with thumb throttle.
I connected the ku63 to q85 with the round cable. Also connected battery and throttle to the ku63.
But when I press the thumb throttle the motor doesn't spin. I tried to check the voltage on controller 3 phases and it ranges 0 to 15v when I press the throttle. Did I miss something? Can someone help please
Do you have the LED control panel connected to the controller to switch it on?
You can't measure the voltage on the motor wires because (a) it's A/C and (b) it's intermittent. If the controller doesn't get feedback from the hall sensors, it stops sending power to the motor.
You can test if it's switched on by measuring between the red and black throttle wires, which should be about 5v.
