YoshiMoshi
I keep seeing elsewhere online that the BMS does not limit the maximum continuous discharge current of the battery pack, but the controller does. Is this accurate? What is the "controller", and where does it reside? Is it on the same board as the BMS?
In my case for a power tool battery pack, does the controller reside in the power tool?
I thought of the maximum continuous discharge current rating as the following:
- The BMS has a rated maximum continuous discharge current. This rating is the maximum continuous discharge current that can be pulled of the battery pack, regardless of the load.
- The power tool has a rated maximum current draw. This may be less or more than the maximum continuous discharge current of the BMS. If the power tool is capable of drawing more current, it will be limtied to the maximum continuous discharge current of the BMS.
- The gauges of the wires connected to the battery connector within the power tool can be used as a reference to the maximum current draw of the power tool, likely with a safety margin. The maximum current draw of the power tool is often considered propitery and not known.
