I'll find some pics and load them. Mercedes crunched the numbers and decided to make a line of "mild hybrid" inline 4 and 6-cylinder engines, that have temporary electric boost to give the 4-cylinder the power of a V6, and the I6 the power of a V8. The I6 now provides 380-lb/ft, 420 HP.
It has a 900-WH 48V lithium battery. The A/C motor looks interesting, I need to find dimensions on it. Rather than run the A/C off of a traditional belt that is connected to the crankshaft, a motor turns it. The steering power assist is also electric, as is the liquid coolant pump for the engine.
As I'm sure everyone here already knows, certain types of motors and generators are very similar in construction, and with a small amount of adjustment to their designs, one device can work well as both a motor or a generator as needed. ISG is Integrated Starter and Generator.
A single thin pancake device is attached to the rear of the crankshaft, and it functions as the starter motor. Once the motor is running, it begins performing the function of the alternator. It also has a third function...when you try to accelerate, it instantly reverts to a motor for a few moments to add electric boost to the crank.
The engine also has a turbocharger, but some turbo designs have a small amount of "lag" between pressing the accelerator pedal, and when the added boost of the turbo takes effect. This turbo also has a 48V motor on it to spin it up to it's designed RPMs much faster.
If you look at the split in the case [on the pic above] the A/C compressor is the upper 40%, and the bottom 60% is the 48V motor...coming soon to a salvage yard near you ?...
