Crusher
cal3thousand said:Crusher said:Hi Guys
Just trying to wrap my head around this. With the parallel boards if I had say 4 6S packs could I charge with one 6series charger connected to the board?
If they are all paralled together on one of the detector boards, YES.
It effectively will make your (4) 6S packs into a single 6S pack, but with 4X the capacity. So, if you are using 5000mAh packs, you have a 6S 20Ah pack. Might take a long time to charge depending on your charger. (Which could be a good thing since it keeps them at a lower charge C-rate)
Ok thanks. One more question if I have those 4 batteries connected in series on the discharge end and still having the parallel board hooked up would charging in parallel be the same or would I have to disconnect the series connections. I think I know the answer but wanted to make sure.
Thanks.
