Mike has pointed out a few considerations / possible problems with making a shifting # 219 drivetrain,
So
Below I have copied and pasted here-from his thread my response to another possible solution to having a mid-drive motor on the swingarm that will allow some gear changes on the rear , so that we can have the best of both worlds.
ScooterMan101
Re: LightningRods mid drive kit
Post Sat Jun 09, 2018 1:26 pm
Interesting, I should have mentioned that when I was thinking about a custom made # 219 chain compatible rear cog set , that I was thinking about about 5 speeds , and a derailleur that had a few machined parts that replaced regular parts that would handle the issues you talk about here.
If it is too much work to make / have made front sprockets and rear cogset that is # 219 chain compatible then ...
Another option is to use the new 8 speed chainring/chain/rear cog , that Sram made for E-Bikes.
And
Design a rubberized crush drive , like that used on the rear wheel of motorcycles , in order to soften the force put though the drivetrain .
For those who do not ride motorcycles here is a youtube video that shows what the crush drive rubber parts look like ... https://www.youtube.com/watch?v=aNTtmp-N1-E
I have been thinking about this for a few years now since I work on my motorcycle and when seeing mine thought of how a good idea it is to have one .
design a small version that is directly on the shaft of the motor. If it would be better somewhere along the drivetrain other than the motor then put it at the location that works out best.
I still would prefer a mid drive where the motor is located on the rear swing arm in front of the rear tire, and that will shift along 5-8 cogs on the rear cassette.
So then instead of a # 219 drivetrain, the E-Bike Specific drivetrain that Sram makes , along with a crush drive in the system.
And do not even have a 11 tooth rear cog, more like 13 t or 15 tooth as the smallest.
With a crush drive perhaps then a regular 8 speed cassette with the 11/12 and 13 tooth cogs removed and two larger cogs near the hub located , ( like what Wolf Tooth Designs makes and sells )
https://www.wolftoothcomponents.com/col ... o-11-speed
( Made it 8/9 speed compatible though )
LightningRods wrote: ↑ I don’t want to sound like one of those expert naysayers that say things can’t be done. Here are some of the challenges in making a #219 cassette (I’m assuming with derailleur):
- In order for a derailleur to work the chain has to have a fair amount of side flex. From the reading I’ve done the chain also needs to twist on downshifts to larger sprockets. Sort of like lifting your inside butt cheek to get up into a tall truck. 219 has tight tolerances and thick side plates. It doesn’t side flex much and it twists pretty much not at all.
- A derailleur by design needs a chain that will tolerate a lot of cross chaining, or not running straight. If you get 219 even a little out of a straight chain line it runs super noisy and wants to derail automatically.
- The pitch of 219 is .303” instead of .500” like the rest of the derailleurs on the planet. This means making all new jockey wheels and cassettes.
- Even in the world of bicycle chain if you compare single speed chain and sprockets to derailleur chain and sprockets you’ll see that derailleur chain is weaker and more flexible, and that the sprockets have much shorter teeth that penetrates less in between the rollers. This contributes to chain skipping under power.
- A built in problem with derailleurs is that on the smallest sprockets, where the fewest teeth are engaged in the chain and loads are the highest, the cage spring is also the most slack. This combination of factors is why derailleurs fail hard when you’re trying to push a lot of power for high speed on an 11t rear cassette sprocket.
My personal OPINION is that the inherent design of derailleurs makes them unsuited to strong chains and sprockets, and therefore to powerful motors. Most internally geared hubs also can not take power too far beyond what a human can produce. The exception is the very expensive Rohloff Speedhub. I have several customers running 3000 watts through them with no issues.
Running a high powered single speed mid drive is a step towards being like a geared hub motor. High amps provide the torque and high voltage provides the speed. Low powered mid drives are way more energy efficient and more bicycle like. A high powered single speed mid drive or big hub motor is just going to murder the little shifter mid drives in terms of acceleration.
