Evelosimo
Hello,
This is the first time I post after months of always finding without having to ask, what a great resource this is.
I recently purchased a used mid drive motor and battery for what appeared a decent price. The motor is a 48V Xofo 15A controller, the 14Ah battery appears to be made of low powered Chinese cells. I finally hooked up the motor for the first time a couple days ago and went for a ride, everything appeared fine at first, with lots of power, however after a few minutes I noticed on the display that every time the motor went on, the voltage went very low, eventually the little battery indicator even disappeared and after about 20 minutes the motor would not even go. That was with a new battery I had purchased, a 8Ah with a rather low powered cell but good quality. I switched battery and then tried it with the battery the motor came with, however after about 5 minutes the whole thing shut down and I have not been able to get that battery to work it again, that is no power. The other battery, which is new and better quality seems to still work but sags a lot until it stops. Both battery were fully charged, they both still had substantial charge after the motor went out or at least my voltmeter said so.
I am wondering what is causing this, could it be a faulty controller on the motor? I imagine since both batteries seem to react adversely. Maybe the older battery that was previously hooked up to the motor has had some damage because the previous owner burned out the controller ( he did not mention any of this but that is a different story)
Any ideas is greatly appreciated as this is all new to me.
Thank you!
Thank you!
